Do GPUS come without seals on their boxes?
Hi Guys,
All the stuff I got for my new PC came with tamper proof seals. Just got a Radeon 7900xtx and the box is not sealed. Should I worry about it? Import date is Jan 2025 and the item looks unused.
some do some dont, which aib card did you get or is it non aib card?
If there is no seal on the box then it should be on the anti static bag.
Which brand did you buy if i may ask? Watch an unboxing video maybe. Does S/N match? Try checking warranty if you can.
It’s the Asrock Taichi White 7900xtx. S/N matches and the plastic peel etc are all on the unit. It looks new alright. The seal on the antistatic bag is easily removable and replaceable back.
Lots of cards these days comes like that. A purchase from a reputed store will eliminate any temper case which i hope you did. I think it’s okay.
But did it have a seal on anti-static bag?
Update - I checked unboxing videos.
And it seems NONE of the taichi cards have seal on the box.
But all of them have yellow caution seal on antistatic bag.
I’m also checking some videos. Yes it had the yellow seal but thats easy to put back also. Anyway it looks new with the plastic not peeled off so I’ll just use it and see. Thanks for the help.
Have you checked if the SN of the card and box match?
I bought asRock x570 taichi motherboard from Amazon , it came without seal. Importer/distributor was devraj computers
So I guess without seal is fine for asRock.
Asked a friend, they replied now.
Yep they also got no seal on box but sealed on antistatic bag.
Same in videos of foreigners,
Same in videos of Indians.
Yes, my Zotac didn’t come with a seal. I confirmed with them, they said the same. Colourful brand GPUs do the same. Idk why
Yes.
