Okay, so I’m going to buy a 40" Series 5 EH5600 and was just reading stuff online and heard a lot about the panel lottery though I could not get anything for this model. So I want to know whether it does affect this model or not.And if it does, should I really have to worry if I get a inferior panel i.e not the SMVA?
Yes, samsung panel lottery will be there for series 5 models like ES5600, EH5000, EH5300 , even in 6 series they have panel lottery scheme.
Why do you want SMVA? its the most average among the three panels used,
SPVA: very good
AMVA: Good
SMVA: Average.
If you want guaranteed SPVA then buy the sony 40EX650, may cost around 45k in grey market.
How to check panel in EH5000 ?
Switch off using remote, then Press info,menu,mute,power buttons at a brisk pace one after another. this is service menu, as your tv is 40inch just look for something like Type: 40A6AF0D or 40R6AF0D, note this down as we can decode panel type from this, Then switch off the tv.
Thanks. Just now checked. Mine is AMVA. It is 40R.
The OFFICIAL 2012 Samsung EH4000/EH5000/EH5300 Owner’s Thread…
Thats good, AMVA is the best panel after SPVA.
Mine is 40R6AF0D. Which panel is it?
Its a AMVA panel.
Thanks!
Hello and Thanks for the imformation
I have a Samsung UE40EH5300 with type
40H6AF0D
Please, Which panel is it? Is it a samsung panel?
Many thanks
my samsung 46es5600 showing 46A6AF0E … which panel it is ?
Its version says TS01 at back of TV.
Refer to this post:
http://www.techenclave.com/community/threads/need-opinions-suggestion-to-choose-between-2-hdtv-panel.144925/#post-1785746
@Spacescreamer: Thanks for help… I think i am having SPVA panel … feels lucky It was bought from Bangkok…
