Drill Machine for Home purposes
Budget: 2k
Is it possible to buy basic drill machine & then buy attachments as per requirement and connect to it?
For 3-3.5 you can get a full set drill + bits etc from skil which is a low cost brand of bosch. The extra money is worth it as chinese knock-offs don’t have a good construction leading to lot of error in the drill center line. Effectively they break a lot of bits and no warranty.
Please give the link for model you are referring to?
How is Pardon Our Interruption...
This Pardon Our Interruption...
or Pardon Our Interruption...
First one looks good…but I already got all types of screwdrivers n all other equipments, other than used in drill machine…
Is it worth spending extra 1.2k or Black & Decker will do the job?
Saw the 3rd one?
get the skill drilling machine 6510. It cost 1150/-, check local shops.. its a bosh owned company
I am using it from an year and its great. The low end torque is excellent. Has both hammer and drill actions
http://www.skil.co.in/skil/l0/product/product.php?gpid=2&pid=
Post merged on Apr 21, 2013
Let me know if you are from Hyderabad.. I can guide you.
@thenvk,
I have a similar requirement and I am from hyderabad, can you please help me.
Thanks.
