Earbuds, excellent NC and low latency
Planning to buy a pair of earbuds, to use with my PC mainly (i.e. for both gaming and multimedia), headphones sometimes feel uncomfortable.
Don’t know much details about audio devices only basic stuffs, every tech product had it’s own rabbit hole. So I asking for buying advice, my budget is from around 5k upto 8k, what will be the reasonable features and specifications in this price range, which ever will be best value for money, I will buy that.
Like two earbuds having the same specifications, one is 6k and the other one is 7k as it has integrated AI assistant in it, I will definitely pick the 6k one.
The brand should be reputable and reliable ofc. Black colour prefered.
Nothing wireless will compare with wired when it comes to low latency.
And if you’re into gaming then wired is the way to go
To not notice lag you need sub 50ms. There is some argument as to whether this is possible with wireless. Even if some products claim to do so
Wired earbuds with ANC will only be USB-C and not many of those are readily available. Easier to get ANC headphones but then that is not what the OP wants. Bit of a conundrum.
There are multiple within your budget.
For instance, Realme Buds Air 7 Pro. It comes with good drivers, good ANC support, and under 50ms latency for gaming.
Go through the reviews if you want to know more.
Prefer getting any IEMs?
I’m actually in the market for earbuds at the same price range. So far I’ve narrowed it down to Realme Buds Air 7 Pro and OnePlus Buds 4. Both have the same specs on paper but OnePlus reviews are more easier to find, and it is almost universally praised everywhere. The Realme is 500rs cheaper.
I’d also had a look at the JBL Tune Beam 2, it was also a good option.
Bottomline is, on paper all the buds look the same, the only way to tell them apart is by trying them on.
If you are going to use those for long hours then be aware of
Noise-cancelling headphones may be linked to rise in Gen Z neurological problems, experts fear
Agreed but I need this one for comfort and ease. Already buying a wired headphone for that, wireless will also serve me in travelling, so that’s a reason too.
never used one, don’t know much about it, heard ztt talk about it though, is it available? Any suggestions?
thanks for suggestions, will watch out for these.
buds 4 looks quite promising ngl
Oppo enco buds 3 pro is the best under 5k. Oppo was one of the audio products companies before they foreyed into mobiles. The audio quality of those are the best with ANC and transparency performance at par with the peers.
