External Battery UPS for PC
Hello I’m looking to get a ups for my pc and would want to avoid the internal battery ones that barely last 2 mins if you’re in the middle of a game. The pc will likely be a 4080 + 7600x running on a MSI MAG 850GL.
I’ve come across these two - "[UPS OFFLINE DESIRE PRO+ 2000](’
Buy UPS for Computers Desire Pro 2000 | Microtek
)" by microtek and the "[APC Back-UPS BX2000UXI](’
https://www.se.com/in/en/product/BX2000UXI/apc-backups-2000va-230v-without-battery-with-selectable-charger-and-flooded-smf-compatible/
)" by apc.
Can anyone let me know how many batteries are required for the microtek ups? The apc seems to require 2 batteries? (Can’t say if it just supports or is mandatory to have 2)
Buying two batteries would be much more expensive than a single higher capacity one from what I’ve seen so ideally I would choose the ups that supports just one.
If anyone else has other external UPS options that they recommend please do let me know! I have considered a regular inverter but the switchover time always concerns me, that and the lack of line-interractive which idk how important it is.
You will be needing 24v battery here so for LA/VRLA/SMF you will be requiring 2 qty as single battery is 12v only.
Also from specs i see that microtek says SWO time of 4-8ms while APC as high as 12ms. So do check hold time of your PSU.
BTW i am also looking for same solution as you and if possible i would go for LifePo4 battery setup as it will have more life in long term
You’re talking about the microtek right? So both need 2x 12v batteries?
The microtek says 4-8ms typically so I’m not sure what the max is. The hold up time of the PSU is 17.6ms so it should be fine either way.
What’s a lifePo4 battery setup?
As per specs yes.
This is Lithium Iron Phosphate battery…either do it DIY or get some of the shelf
@@rsaeon can guide you better in that aspect
I suggest you go for APC because it offers automatic shutdown in case you configure it to do so. It comes with PowerChute shutdown software.
I don’t believe LifePO4 batteries will work with these UPS units. You might encounter charging problems. Please correct me if I’m wrong.
Wrt LA batteries LifePo4 are the nearest matching one in lithium batteries… @@rsaeon is the better person to chime in here
If the charging voltage doesn’t exceed 14.6 (3.65V x 4), it’s safe for LiFePO4. For 2x12V, that would be 29.2 (3.65V x 8). You can overvolt a bit (some BMS go to 3.75V), but it’ll noticeably degrade the battery pack’s life.
The bigger concern is this (the entire thread is worth going through):
Yeah the lifepo4 batteries seem like they’re beyond my level of understanding or willingness to DIY stuff. I’ll probably just stick with the lead acid batteries despite them being worse. I saw this on Amazon that seemed interesting but given my lack of knowledge on any of this I’m unsure if it’s worth it -
https://amzn.in/d/bh6Pqp5
It would be too expensive either way given I need 2 but yeah lifepo4 batteries got me curious about easy alternatives.
Coincidentally even im in somewhat similar fix as OP. My 1100va is not holding my PC (7600x CPU,850wPlat PSU,7700xt) and it starts tripping and beeping while gaming so went for 650va UPS just for the OLED TV and cutting close with the 1100va for the PC for time being. Now I ordered a 27" Monitor to separate my PC and want to update 1100va to 1500va. I didnt know there exist a concept of external batteries. Can someone throw some light on this?
Just figured I would update this post. I went ahead with the APC BX2000UXI along with two Exide 100ah batteries.
It’s been over a month and my experience has been great. My current pc has a corsair cx650m which has a pretty short hold up time of just 9.7ms and it hasn’t shut down yet even once.
The new pc should hopefully work just as well and last at least an hour if there is a power cut. It has a RM850x shift which has a holdup time of 23.2ms.
I’ve seen people recommend going for a pure sine-wave inverter but after seeing various opinions online and the fact that most people use a small ups which are all simulated sine-wave (me included for 4 years prior) I don’t think pure sine-wave is extremely important for pc components nowadays.
Overall would recommend this setup for anyone looking for an alternative to a small ups with a fast switchover time.
That’s great to hear. How much did it end up costing? UPS + batteries + installation?
The ups was 13.5k + 20k for two 100ah batteries + 5000 for installation and wiring to two dedicated outputs. Might have been able to get the batteries for cheaper but my dad wanted to get it from our previous inverter guy.
