Looking for a phone that supports jio 4g LTE for a senior citizen who’s not tech savvy.
You can try the JioPhone, it’s purpose built for that use-case.
sama
July 23, 2025, 3:32pm
3
I had one listed that is not in use. If you think, this option will work, then let me know.
Was purchased in June of last year just to keep a number alive on the JioPhone plan. SIM can be used outside the phone after recharge, but you will lose outgoing calls and data if you do so, though outgoing SMS and incoming calls work fine in another phone.
Works decently well for calls with call recording. FM radio is a long-lost feature as is the 3.5mm jack. Supports microSD cards of up to 128 GB to be used as a music player.
Otherwise you can use it as a handy torch without worrying about l…
Jio Bharat B2 (cheaper) or
JioPhone Prima 2
The difference is of only build quality.
Prima 2 has a snapdragon Soc whereas B2 has Uni Soc.
Prima 2 comes with extra pre installed apps such as Facebook, jio apps.
