File copy speeds with a 64GB SanDisk Ultra Luxe USB flash drive (SDCZ74-064G-I35)
I (recently) bought a USB flash drive after more than 10 years.
The last one I got was gratis, courtesy this forum :slight_smile:
SanDisk Ultra Luxe USB 3.2 Gen 1 Flash Drive.
64GB, “Speeds upto 150 MB/s READ” (SDCZ74-064G-I35)
For UFDs, synthetic tests like Crystal DiskMark (and therefore most reviews) are meaningless.
I wanted to know what I could expect on my system.
Test System : USB 3.2 Gen 1 (rear port), source=SATA SSD, BX500.
I wanted to have a bootable UFD so I created one active FAT32 partition and one NTFS partition.
These tests were carried out with the NTFS partition.
These are file copy tests, I still can’t figure out how to carry out a pure file read (or write) test.
UFDs are never used as boot drives, mostly used to hold/save data, so a file copy test is the most ‘sensible’
Powershell script used. If anyone wants it (to, maybe, test a shiny new NVMe SSD :wink: let me know.
File copy speed varied from 22 MB/s to 58 MB/s.
Speed seem to depend on individual file size; and, if copying many files, the number of files.
e.g. the test reporting 22 MB/s had one large file of 3500+MB.
Pics attached.
wow! that’s mpt even half the advertised speed!
SanDisk says “150 MB/s READ”.
I was able to read files at 100+ MB/s.
I have a SanDisk pendrive with 400 MBps read and 200 MBps write. It touches that speed on SpeedOut with very small sequential files, so they have it covered from a marketing perspective.
It will not display such results with sustained read/write on normal tools. The native flash usually settles in the region of 60/30 for such drives once the really small cache runs out.
Same tests with a 10 year old “SanDisk Extreme 64GB USB 3.0 Flash Drive With Speed Up To 245MB/s-SDCZ80-064G-GAM46”
(Read Up To 245MB/s; Write Up To 190MB/s)
Cost USD 35 in Sep 2014.
Having a large file, 3500+MB, did not impact file copy speed.
----------------------------- posts merged -----------------------------------------------
Same tests but in reverse : UFD to SSD.
Should give some indication about the UFD read speed.
