Full custom watercooling guide!
To help all those noobs out here planning to put together custom water cooling system i made this guide.simple as that
INTRODUCTION-
This is what we are talking
Custom loop ,open loop or whatever you may call it is a nice addition to your existing pc.
It provides many benifits
BENEFITS-
Killer looks
(u already knew.right?)
Excellent performance
(hardware runs silent,more cooler and with less pain.) also opens up a whole new level of over clocking)
Increases life of your hardware
(Well unless u don’t break something.you hardware will run cooler and last longer.again unless you don’t break or crack something)
Silent System-
(Yeah since there are less lousy fans)
COST-Generally people feel it will cost upwards of 20-30k and hard to find in india.
Its not true and you can even have a custom cpu+Gpu loop running under 5k!
In the end cost will depend upon how much you spend.i mean it!
companies like ek or swiftech are usually wayyy more expensive (more on companies later) as opposed to XSPC or barrow.
BRANDS-
The absolute best And I mean It Absolute best products are Almost all from EKWB (through the cost will break your bank) followed by SWIFTECH (which is one of those old experienced companies) and second best choice after EK
XSPC is the best one to go when on a budget.no questions asked.:slight_smile:
I will speak more about companies and brands later on.
PARTS
There a some main parts in a water cooling system obviously something like this requires a lot of stuff (well alteast it looks better than alienware warez
WHERE TO BUY in INDIA
Me(i got a pile of water cooling products and can suggest/make a loop for you,you can also Contact me to buy water cooling gear,got a stock of everything,always)
Ekwb.com -ek sells the best or nothing ,its the buggati of watercooling .but buggati costs paisa
Aliexpress.com-there are a lot of watercooling products over AE and most are dirt cheap Seriously!!!go and have a look
Frozencpu.com-shipping an issue,but its great
Perfromance-pcs.com again high shipping, otherwise great
Ebay.com-got everything,shall i say more
So you are ready.go and upgrade your pc!
NOTE-i am yet to 100%complete this guide pardon any rubbish
Fell free to contact me for advice or building/sourcing water cooling stuff
P :confused: i have not showed fanboyism and whenever i say product A is better than B i saw reviews and benchmarks
Hey buddy, can you please PM me, i want to go for a custom cooling loop.
thanks :slight_smile:
Good initiative @@PHOENiX117 but since you’re been around the block watercooling before, why not share some pictures of your rigs that you have WCooled as opposed to a Digital Storm custom build and Skunkworks?
lol i am lazy.
Will do it soon
