Good quality Power bank with fast charging for family.
Looking hot good quality power bank to be used by all in family.
Different brands mobile Samsung, Redmi, Vivo, apple, etc.
Fast charging
Budget around 5000
20000 mah
Led light indicator
Good quality for long time use
Not sure what else is required
(but fast delivery preferred to Mumbai)
Xiomi Powerbank 4i 20000 or Samsung 20000mah Powerbank. I’ve used both and both are good.
It was urgency hence bought this from blinkit.
https://blinkit.com/prn/portronics-luxcell-b-20k-22.5w-20000mah-power-bank-(black
)/prid/560841
Amazon reviews however, say its pathetic.
https://www.amazon.in/Portronics-Luxcell-Advanced-Battery-Display/dp/B0D3596YR4/
Kinda mid
I have purchased this URBN power bank -
URBN Lithium_Polymer 20000 mAh 22.5W Super Fast Charging Ultra Compact Power Bank with Quick Charge & Power Delivery, Type C Input/Output, Made in India, Type C Cable Included (Camo) : Amazon.in: Electronics,
frequently around 1k mark. 20000 mAh. Does fast charging works on atleast Oppo and Apple devices from what I could test.
One of family member actively using power bank hence looking to buy another.
Features:
  1. Quick Charging (both power bank and phone using power bank, my mi Quick charging is at 67w)
  2. Led display (to show power back battery status)
  3. Budget around 5k
  4. 20000mah
If any suggestions do reply.
Ty
I have one 20000mAh from Anker. Gets charged pretty fast. Also, it’s pretty durable. Have dropped a few times, still works good. Been 3 years
Can you post link please ?
I got some more suggestions from a friend @@kunnalthapa
https://amzn.in/d/f6CLyN5
https://amzn.in/d/i5n9ums
https://amzn.in/d/9iBzBbn
With little more budget, this one’s got Silicon Carbon cell
https://amzn.in/d/i2GbjV0
I’d say go with mi
30k mah 18w
https://www.flipkart.com/mi-30000-mah-18-w-power-bank/p/itm1f0dc048d0d6e
20k mah 33w
https://www.flipkart.com/mi-20000-mah-33-w-power-bank/p/itme2dae8e64d942
20K MAH with 33w is sweet spot for the price @ Rs 2199… Infact in big sale you can at Rs 200 or 300 lower also
@@Futureized you can go with this 33w unless u really need 65w or 87w or 100w and that too if willing to spend that much for that speed
Yes, and prime day is coming up so it would be available around that price soon
Used to fast charging, hence looking for 65w or above (65w is enough as mi charger is 65 or 67)
Why not get a laptop power bank ? They typically have at least 60w PD ?
Don’t go with 30k mah. A lot of flights do not allow above 25k mah
Wow I didn’t know that.. Thank you for informing!
btw how will they come to know whether it is 25000 or 20000 or 30000 mah ? just for knowledge asking this… curious to know
They might ask you to show them specs (that are generally printed on a label on the power bank). I know of someone who had to show the Wh of their power bank. IMO, you should not take any risks while flying.
I didn’t know this earlier, but
https://www.mi.com/in/product/mi-powerbank-boost-pro-30000mah/
Even xiaomi mentions it on their website. I just checked their website
But still, what is the reason for this? Like can the pressure difference cause the cells to explode or something? Asking because even laptop batteries have a limit iirc
Basically more power equals more lithium ions. Flights are pressurized environments. Do changes of ignition, explosions are higher
