Graphics Card for 4 Monitors
Hello Community,
Can anyone tell me if they are using a Graphics Card with 4 Monitors.
I am looking to connect 4 monitors to me Desktop and looking for an appropriate and cost effective soution
Gigabyte GeForce GTX 1660 Ti Windforce OC is the perfect solution for your 4 monitors with the price of Rs.3,890 and it also can be deliverable
GTX 1660 Ti for 3890 ?
I think you should get one of the entry level ones with display port and use a mux
Else 2x GPU and use them to drive all outputs. I believe the term is daisy chaining
Thanks you guys for your suggestion.
@@Sanjeen9910 I took a look at GTX1660 and its priced at 17,000 on Amazon,
https://www.amazon.in/Zotac-GeForce-1660-GDDR6-Graphic/dp/B07NMWQXLR
Can you please share a link where you saw it for 3890 ?
Regards
Vaibhav Mishra
If you are not a gamer then you can try for thse two. Keep in mind that you need a 6 pin power connection for the nvidia and a 8 pin for the AMD card.
AMD has 1 HDMI and 3 DP ports whereas its the opposite for the nVidia card. Search a bit for actual user experience on google before you pull the plug.
https://mdcomputers.in/powercolor-red-dragon-rx-570-4gb-gddr5-axrx-570-4gbd5-3dhd-oc.html
https://mdcomputers.in/gigabyte-gtx-1650-windforce-oc-4gb-gddr5-gv-n1650wf2oc-4gd.html
