Okay so I have a HD6XX which originally was on my desktop PC with Schiit Fulla and I used to listen to it with itunes because I have Apple music subscription. Later I got a macbook air m2 and it just works fine with it.
Now, comes the problem. Changed jobs and new work gives me a M1 macbook pro but since I am almost always on corporate network and we are not supposed to use my apple id on it I cant use my headset to listen to apple music while working.
So I am thinking of this type of solution where I get a nice desktop amp which has bluetooth so that I just play music on my phone and listen on the amp. is my thinking correct? any better solutions? basically I want to run my HD6XX which are 300ohm headphones over wireless with highres audio.
if you want something portable
Or
For pure desktop use
I would rather invest in a wiim mini or pro and couple it with a chifi amp like aiyima A07 or fosi 03
Woukd give you bt as well as wifi streaming capabilities with good dac performance
Which gen fulla do you have?
I believe you need a lighting to camera USB adapter. The original apple is 3k or so, a generic one will be 1 k ish. You will also need a usb pd c adapter
