Headphones causing Health issues (Hearing problems)
So thought I will put this here as a health issues advisory .
Suffering myself for hearing issues in from mid-20s due to heavy use of headphones .
Even my relationship suffered because of this
But thankful I am better now. 70% .
I will strongly advice not to use in-ear headphones specially and less your use of tws as much as possible
Over the ear headphones are little better but even they are not exactly the best .
Maybe bone conducting headphones are much more safer. And I am soon Going to shift to that from over the year headphones.
Lot of measures you can take like as suggested by fellow members .
Keeping Low volume.
Taking breaks.
Using it for limited or only when needed.
However the idea as put by one member to take to shower is a poor idea in my opinion. There is big risk of damaging his ears even if it says water proof as any small opening or leakage will cause short-circuit and might damage the ears badly.
Hope this helps and other members can contribute to it .
My use is mainly podcasts. So voice at volume no more than 50%.
The problem arises when you increase volume to compensate for louder ambient noise.
I say get ear defenders and you can listen at low volume. Especially if you don’t like iems and go for open design which has no usable sound cancelling
AirPods are ear killers if you listen for long and at loud volumes
Even if at medium volume ..it should not be used for too long .
iOS devices have hearing protection, once set it will let not let the volume go to damaging levels, no matter how much you try.
Even Realme and samsung warns me not to increase the volume .
Prolonged continuous use of IEMs (which seal the external ear canal) can lead to ear infections beacuse they create a closed and humid environment which promotes the growth of infectious organisms. Always take breaks in between prolonged listening sessions. and low volume for long durations can also cause hearing damage, it need not always be high volume.
One tip I would add is to avoid In-Ear earphones. I hate them. It feels like they are pressing against my brain. I exclusively use old-school earphones from Sony. To enjoy the Wireless experience, I bought a Bluetooth receiver for 250 that makes the wired earphones wireless. It gives a battery backup of 1 hour, and I can swap out the Bluetooth receiver when the battery goes down with a charged one.
People should clean their ears with soap while taking bath and also clean the iem and ear tips with sanitizer or 99% iso propyl alcohol to avoid such infections. After cleaning the ear tips with IPA, i’ve noticed the fit is much better. I don’t keep volume above 35% in laptop and above 25% in phone. If ambient noise is too high i stop listening to music or videos completely. Better safe than sorry. I’ve lost hearing in one ear temporarily for 4-5 months after some retard blew a horn near my ear. I had to clean blood from my ear for weeks after the eardrum punctured.
I recently went to an ENT for a slight itch in one ear. He said there’s an infection but it is mild so it will be okay, and he prescribed antibiotics for a few days.
The main thing he said is never put anything in your ear, not cotton buds, not water, not even ear drops. He said the wax comes out on its own and you should only clean the outer ear. Ear drops are to be used only in specific circumstances, and when prescribed by the doctor. I myself used to put water in the ear when bathing, but I’ve stopped now.
I also told him I use headphones for half an hour to an hour everyday when I exercise, and he said it’s okay, but don’t keep the volume too high and not for extended durations. Of course, there’s no point in his saying don’t use headphones or earphones, because people nowadays are going to use it anyway.
One thing I’ve done is switched from in-ear earphones to over-the-ear headphones. Use of both promotes bacterial growth in the ears, but it is much more with earphones.
While we should clean the ear auricle (pinna), ideally speaking, we should not clean the auditory meatus (it is approx 3 cm long, we can still clean the outer 1/3rd caritagenous EAM, inner 2/3rd is a big no). And no matter how well you clean, it won’t be sterile. There will always be residual skin flora left behind (which is perfectly normal, they stay trapped in wax and the cilia continuously keeps on pushing then outside, it is a self cleaning mechanism, nature has taken care of it).
So what happens is that when you keep the IEM for prolonged time, the residual flora gets a favourable environment (moist and warm) to multiply. That’s what causes the problems (infections). Hence it is adviced to take frequent breaks in between prolonged use.
It is a really great advice to clean IEMs with IPA. I frequently clean my IEM ear tips with IPA and the seal is amazing after that. Kills the microbes on IEM too. But I do it for the amazing seal, killing microbes is a by-product :face_with_tongue:
@@6pack Sorry to hear that, hope you’re doing better now.
It is a misconception that bone conduction earphones are safer. They bypass the eardrums but still stimulate the cochlea for sound, same as any earphones. In fact, because of lack of isolation, the volume is usually turned up by users, resulting in more damage.
I have found that having ANC on at full (specifically from Bose, Sony, Apple) is the best way to reduce the actual decibel level impacting the ears.
:check_mark: yes this is the right way, listening at low levels with ANC on
Thank you for saying this.
There is another misconception that IEMs are worse than earbuds/openback headphones also. Argument is that IEMs seal causes hearing problem or something like that, at least that’s what I was told by my parents and friends a long time back.
On the contrary, with earbuds/openbacks people crank up the volume to drown out the external noise. Which damages hearing more.
IEMs provide noise isolation, sometimes ANC also. That reduces the need to increase the volume so much. Overall, proving better for relatively prolonged usage.
Nonetheless, Loud volumes in general should be avoided.
If there is no need for earphones, say for privacy or disturbance, then a loudspeaker at low volume is always better , both sonically and ear health wise.
But no certification is there for ANC. Not suitable for industrial applications. Unlike with ear defenders.
and
Can you give the link of receiver?
https://www.croma.com/portronics-auto-14-wireless-2-in-1-audio-adaptor-one-button-control-por-1153-black-/p/230917?srsltid=AfmBOoqsL8292cF8EAJNLfDgMRNJnBf_4I5ozluGTfPKpgFObRuygst0
I dont know what @@Superhind is talking about.
But I have this portronics one and I have tested for 10 mins or so. It was pretty decent.
I remember back in Sony Walkman series phone days (before 2010), I used to this have this Sony clip on Bluetooth receiver with female 3.5mm port. That worked beautifully.
I still have it somewhere. Black square
https://www.flipkart.com/sony-sbh20-in-the-ear-headset/p/itmewd8a7jjsdktn
Yes this one but I had something else. It was like a stick kind of with female port on top. I will see if I can find a pic.
Something like this..
Higher end [SBH54](’
https://www.amazon.in/Sony-SBH54-Stereo-Bluetooth-Headset/dp/B0154G9CYY’
