Help choosing between TP-Link Omada and Ubiquiti for a new home network
I’m setting up a new home network for smart home devices running Home Assistant.
Please note my smart home setup will use multiple protocols including Zigbee, Matter, and Wi-Fi.
I need advice to pick the right gear.
Requirements
  • Home Assistant as primary use.
  • 2 indoor access points.
  • 2 PoE cameras.
  • VLAN support for device segmentation.
  • Prefer predictable management and future expandability.
TP-Link (Omada) plan
  • TL-SG2210MP JetStream 10-Port Gigabit Smart Switch — 8× PoE+, 150 W PoE budget.
  • OC200 Omada hardware controller.
  • ER605 Omada Gigabit VPN router — 1× WAN (gigabit) + 2× WAN/LAN (gigabit).
  • EAP610 Indoor Omada Wi-Fi 6 AX1800 access point.
  • Total price ~ ₹35,000.
Ubiquiti plan
  • Cloud Key / Gateway Ultra.
  • Access Point U6 Plus.
  • Switch Ultra 7 Port, 60W.
  • Total price ~ ₹55,000 (I don’t mind spending the extra ₹20,000 if it’s genuinely worth it.)
Questions for you
  • Which is easier to manage locally (no cloud dependency)?
  • Which has more stable firmware and long-term updates?
  • Is the Ubiquiti premium worth the extra ₹20k for small home use?
  • Any real-world advice on PoE budget and camera power needs?
What I’d like from you
  • Share pros and cons based on experience.
  • Point out any gotchas with the listed models.
Thanks for any help.
If going for Omada, don’t go for EAP610, the coverage is abysmal. You’d need to get EAP650 or higher. I was previously using an EAP610 and then switched to EAP670.
Avoid the OC200 controller - it is not going to be future proof plus is slow. Rather run your own controller on Raspberry Pi or the equivalent, or use the free Omada Cloud Essentials. The latter will mean that for most changes, you are relying on the cloud.
I have a UCG Ultra + U6+ AP. The UCG Ultra is significantly more capable than any TP Link Gateway, especially if you want good firewall features and IPS/IDS/VPN. TP Link does not mention the hardware of their gateways, Unifi does. Unifi is typically more proactive with security updates, they have an active bug bounty program while TP Link does not.
On the other hand, the U6+ is nothing to write home about. They are pretty much comparable to Omada AP, but it costs roughly the same too.
Unifi switches and cameras I feel are overpriced. If you already are on the Unifi ecosystem, they give you a nice centralized place to manage stuff, especially for switches, but otherwise there is no advantage over say TP Link switches at half the price.
You don’t need a Unifi switch for 2APs in any case - you can get 2 POE injectors or a cheap TP Link PoE switch. So UCG Ultra + 2x U6+ + 2x POE Injector = 40k roughly.
Both can be managed locally. Unifi should have better long term support for their devices with firmwares. TP Link is notorious for not updating the firmware of their old devices. They release multiple versions of the same product and drop support for the older versions.
I personally bought Unifi because of their better firewall, security posture and a longer term product updates. The only product I can say is absolutely worth is the UCG Ultra. You can do a lot more with it than TP Link. For example, a couple of things I use: Put your IoT devices or cameras on a separate VLAN. The IoT VLan cannot access the Main VLAN, they can only reply back. You can run a VPN Client running on the router, and map a SSID to that VPN connection so if you connect to the SSID you automatically get routed over the VPN. Not sure TP Link supports these use cases.
Thanks for sharing this information.
The only thing I would add is that the primary reason to go this route over a reg router is when you want to add multiple APs so that there is at least one in LoS from all corners of your house.
I see you have added plenty of equipment for both options but a single AP which makes the whole upgrade (?) kinda pointless.
Do not assume that one of these APs will somehow give you better range/coverage than a standalone router - it simply won’t.. If anything, it will likely be less
Yes, for now I’ll be adding 2 access points to keep the budget manageable. Later, I plan to add 2 more once things are more settled, as I’m setting up this house from scratch and purchasing everything it needs.
You can also look at grandstream and hikvision for IP cams and NVR
