Help me choose a rj45 crimping tool from these
Or suggest any other in similar budget
Are you a pro or is it for home use ? If for home use , just get the ones from offline stores for around 200-250 .
Home use only
Offline pricing is also ~350 here, i thought why not get a better product by spending 150rs extra
Try and find something in this form factor:
is the most suggested on the home networking sub.
also, what @rsaeon has suggested - something with a ratcheting mechanism is recommended.
