Help me configure a pocket rocket!
Q: What is your budget?
  1. 50K
     	[*]Q: What is your existing hardware configuration (component name - component brand and model)
  2. CPU - AMD 955 BE
  3. *Motherboard - Gigabyte *GA-MA-785GMT-USB3
  4. GPU - ATI 5850 Twin Frozr
  5. RAM - Gskill Sniper 16 (4x4) GB DDR3 -1600Mhz
  6. Monitor - Dell G2410H
  7. SMPS - Corsair VX550
     	[*]Q: Which hardware will you be keeping (component name - component brand and model)
  8. RAM - Gskill Sniper 16 (4x4) GB DDR3 -1600Mhz
  9. Monitor - Dell G2410H
  10. SMPS - Corsair VX550
     	[*]Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
  11. CPU - Intel Core I5/i7
  12. *Motherboard - any compatible motherboard Micro atx specifically and only Gigabyte *
  13. *GPU - Nvidia/Ati - Good enough to last me for 3 years and should fit a micro-atx board/cabinet *
  14. Cabinet - Conservative design like the Antec p180 mini or something similar to the Alienware x51 chassis. The cabinet should have a Small foot print should be able to handle 4-6 hard drives and good thermal capabilities although a mesh design and bright leds/lights are not cool for me
     	[*]Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
  15. Yes, will upgrade the following within 6 months
  16. SMPS - 600W
  17. Cabinet - CM XXX
  18. RAM - 2X4GB PC8500
     	[*]Q: Where will you buy this hardware? (Online/City/TE Dealer)
  19. Mumbai/Ahmedabad
  20. Open to online purchase
     	[*]Q: Would you consider buying a second hand hardware from the TE market
  21. Yes
     	[*]Q: What is your intended use for this PC/hardware
  22. Gaming - the ocassional FPS/Racing
  23. Browsing
  24. Desktop Processing - vmware/red hat linux/software testing etc
  25. HTPC
  26. Download rig, 24x7 operation
  27. Watching HD movies
     	[*]Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
  28. Asus - don’t like their rma/after sales services
     	[*]Q: If you will be playing games then which type of games will you be playing?
  29. *FPS - *Anything graphically intense at maximum settings
  30. Racing - Anything graphically intense at maximum settings
     	[*]Q: What is your preferred monitor resolution for gaming and normal usage
  31. Gaming -* 1920x1080*
  32. Desktop - 1920x1080
     	[*]Q: Are you looking to overclock?
  33. yes - maybe
     	[*]Q: Which operating system do you intend to use with this configuration?
  34. Windows 7 64 bit
  35. Linux - Red hat/fedora
I want the system to have a very small footprint and would like basically like to have something very silent and compact. Gaming is something I rarely do - only the occasional new releases. No online/multiplayer gaming. I would like to have the cabinet/case to be as conservative as possible i.e no bright leds and garish teenage led fans and crap. Simple classic design and elegant lines.
I can wait for the new upcoming Intel/Amd releases. I want to keep this pc for 3-5 years as my requirements aren’t very high.
Well here me goes –
Intel Core i7 2600k ~17500/-
Gigabyte GA-Z68P-DS3 OR Gigabyte GAZ68XP-UD3 OR ASUS P8Z68M-PRO
Corsair Carbide 400R ~5400/-
AMD HD 7850 2GB ~17500/- OR AMD HD 7870 2GB ~22500/-
AMD HD 7870 / 7850 2GB review → http://www.techpower…D_7850_HD_7870/ / http://www.hardwarec…850-review.html.
The HD 7870 is a beast of a performer and I will vouch for it because –
Justification for the ASUS motherboard –
Can you wait for mid-range Kepler and Ivy-Bridge CPU’s to release they might add more dimension to your limited choices and will really make a more comprehensive buy, due to these reasons –
  • AMD 78** series currently has no competition, how Kepler [GTX 670 / GTX 660Ti] offerings from nVidia will affect this segment will be interesting and will see more palatable prices on menu.
  • Ivy-Bridge is due this May, might be, might not be what you need. But will add some depth to your choices.
Hope this helps, Cheers!!
^^ What about the cabinet? - that is the most important thing for me.
Already mentioned earlier but enunciating a little more clearly –
This is a full atx case. I want some thing small and compact.
Something like the Antec p180 mini. - Best PC Case 2024: Top cases for all budgets & builds
I think this page will help you better Sire, I am not very knowledgeable about SFF PC’s.
Hope it helps, Cheers!!
Yo,ALPHA your first Gigabyte mobo link is leading to stalker 2 youtube video :face_with_tongue: and you’ve mentioned a new proccy i5 2600k,do correct that.[quote=“ALPHA17, post:2, topic:202079”]
Well here me goes –
Intel Core i5 2600k ~17500/-
[/quote]
Thanks, corrected.
