Help needed with air purifier hepa filter
So I have a Breathify air purifier bought around 2 years ago. I also bought a filter with it just in case. Now the issue is that it is not in stock on their website and me being in Delhi need something urgently. The size of the filter is 12x8 inches but most of the companies do not mention their hepa filter size so I can’t order any filter just like that.
Can you guys please check the size of your hepa filter and let me know if somebody has a filter of same size that is easily available in the market or online?
If you don’‘t find an exact fit, you can try to get something smaller that will fit inside and then seal the gap with some tape or similar. Hopefully will be fine. And then you can search for filters with better fit for future.
I stock up on 2 years of filters ( so 3-4 spare for me) to avoid any hassle, although ikea usually keeps them in stock.
I guess that’s what I would have to do. I do have one spare at the moment but needed to buy some more for future. Might buy another purifier as well.
Can someone tell me how’s the Cuckoo Respure? I am eyeing this one.
Maybe something you’ve already done, but put in a support request or a complaint? It’s their responsibility to provide such an essential spare. Maybe the easiest path to find one since it’s unlikely you’ll find a matching filter.
Did u contact their customer care?? As they claim they are manufacturing locally I dont think they sd have any problem in supplying their customers…Plz first contact them…I am confident they will help
I did contact them 2 days ago. It should be in stock in 2-3 weeks. But now I am looking to get the Cuckoo Respure instead of getting hepa filter for breathify as the filters on Cuckoo are pretty big and they have pre filter and carbon filter as well. Their filter is also somewhat the same cost as breathify.
I will keep the breathify in my room or just send it to my parent’s place
