I have a peculiar problem with my home theatre.
It has apple TV + Denon amplifier (X1700) + Epson projector(TW7100).
It was working well until recently.
4k HDMI cable or 8K HDMI cable does not work but a 2014 old HDMI cable is working.
Following is the scenario:
Apple TV direct to projector with 4K cable - working
Apple TV to Amplifier to projector with 4K cable - not working
Apple tv to amplifier to projector with ordinary 2014 HDMI cable - working
Apple TV to Amplifier to LG 4K monitor - working.
I am not able to decide which HDMI port is at fault to send for service.
It sounds to me like a signal compatibility issue between the Denon amplifier and the newer HDMI cables. Maybe due to strict timing or shielding in the high speed cables. Also the ports could be faulty, but the amplifier may have issues with certain cables.
You may want to try a certified Ultra High Speed HDMI cable less than 2 meters long for best compatibility.
Could you define ânot workingâ? No display at all? Or something else?
Most likely though, this is a cable issue. For scenario #2 and #3, is the resolution same or does using older cable also reduce the resolution to 1080p?
It was working well for over 14 months with a 8k cable. The problem started a week ago
not working = no display. Projector is not detecting the cable. Older cable is showing the display but could not verify if it is dropping the resolution. Anyway the projector is not a native 4k display but upscales to 4k
Can you set the target resolution of the source manually to 1080p and check? Are you also using the same set of cables to connect the 4k monitor? Is that getting a 4k input?
If the monitor is getting a 4k input with the same set of cables then most likely the problem is with the projector. Typically these have 2 HDMI inputs, so you could try connecting to the second one to see if that works as well.
Itâs the cable. But, I am not sure if a better cable is going to help you with Apple TV (4K, I am assuming). Apple TV 4K sends a signal in very high bandwidth which makes a lot of cables struggle especially when an AVR is involved in the middle. It was one of the reasons I stopped using Apple TV. Try a different source other than apple TV. Most likely your problem will be solved. I donât think there is a problem with any of your HDMI ports.
Agree, you need to use high quality cable with apple device, there is a video explaining difference between cheap usb c cable vs apple usb c cable for display and thats crazy how many other component they put into cable for signal processing.
I will try to set it manually and check. The same set of cables was used to connect to the monitor and it works at 4k. I tried both the HDMI inputs in the projector but no success
Yes I will try a different source and try.
Can you try this as well? If it is a bandwidth issue, it should at least show 1080p properly.
OK some good news.
I bought a 4k cable from Amazon â[Storite 15 Meter 4K HDMI 2.0 Cable with Ethernet, 4K@60Hz, UHD Resolution, 3D, eARC 18Gbps Ultra High Speed Transmission, Compatible for All HDMI-Enabled Devices (Black)](â
I connected a Honeywell 8k cable from apple TV to the amplifier and the above storite cable from the amplifier to the projectors HDMI 2 port. It did not work. But when connected to the HDMI 1 port it started working.
So at the moment I need to settle at this setup and carryon as long as it works and debug latter. I cannot identify exactly which HDMI port is at fault in the projector or amplifier as all of them work in some combinations and type of cable.
If it is not delivered, I would recommend you cancel this cable. It is only a question of when (if it ever works) it is going to fail, not if. Wire based HDMI cables donât work well for such long distances even at 1080p forget 4K. You need to buy an optical HDMI cable if you need such long distances, but, even that failed for me within a year as high quality ones cost a lot and I bought at a time when aliexpress used to deliver to India and these cables were not available here.
As I mentioned it is already delivered and working. I have to take my chances now. Do you have any link to the optical HDMI cables and likely cost?
As for the failing part, I agree with you. The initial cable that worked for close to 18 months costed me 17000 rs for the 45 feet and a well known brand (Monoprice)
I gave up trying to get 4K on my projector. I watch in 1080p with copper HDMI cable. It doesnât get used enough to justify 5k or more every few months.
You are right. It is not even true 4k but a upscaled to 4k in the projector.
Cables this days are just mess, I have a 4k hdmi cable when i attach to my 2k monitor it send signal my pc that i have 4k res and my pc res changed to 4k. It is really good and thick cable with noise filtering. While i have other cable which came with imported german machines as spare for use in 1080 monitor looks cheap, thin and without any filtering work as charm for 2k 144hz.
