hello
well finally i have decided to go with amd build
final few queries..srry for making a new thread
1.Can u suggest me a good mobo for amd 955 phenom2 x4 BE
i have selected few msi gd70/65.how is it for ocing. Are there any better
boards by gigabyte
whats the major diff btween 70/65
2.Going for Glacial tech 650w psu ..will it be enough for the needs ??
read some good reviews abt it (>80% efficiency)
so here’s my final setup
1.Processor- Amd phenomx4 955 BE 3.2ghz
2.Mobo-mostly msi65
3.Psu-Glacialtech 650w
4.Gfx-MSI N275GTX Twin Frozr OC
5.HDD-500gb WD
6.Ram-4gb Patriot ddr3 sticks
7.Antec900/902 case
8.Screen-Dell 24" full hd S2409W
9.Heatsink-CM hyper212
10.Keyboard/mouse - already owning razer copperhead/lycosa
11.Speakers-planning to continue wid old Altec lansing 2.1
well thats it apporx 68k ..budget was 70
any last suggestions are welcomed
ty all for helping me …cheers
gl hf ~
gigabyte 770 mobo is gr8
Budget Socket AM3: Gigabyte MA770T-UD3P Mainboard Review - X-bit labs
this is a good mobo, and only downside is it got only one X16 slot. It suuports DDR3 1600, all solid caps, gr8 oc features, and rock stability for ocing.
Heard its around 5k.
which getting PSU, make sure its Al650AA, not AL650A.
AA is gr8 and is 84% effiecint and overloads upto 730W stable and still 82% efficient.
Gte some high performance 120mm fans for around 500~600 each with a minimum cfm of 90 to all way upto 130cfm. Above 130 wud be very noisy. Cm 90cfm LED models for 500 are cool.
Petra’s Tech Shop
already got those
had got em long back ..wen my fr8 was cming to india frm usa
But 38cfm is more or less than a normal 120mm fan.
For better cooling u shud look for atleast 90cfm.
hmm ok wll check out
@also 1 more thing .about UPS
can u brief me what stuff is required, have no idea about it :\
around 1k/1.5k .i hope that would be enough
GD70 is a way better mobo for the 955 as compared to the G65. Also have a look at the gigabyte 790 X model and the M4A79 T delux from asus. These are the top 3 as of now with the asus crosshair 3 still to come.
a corsair 550WVX would be better.
whats the budget for the mobo ?
MSI 790GX-G65 ~8.5K
MSI 790FX-GD70 ~11.5K
Gigabyte 790FXT-UD5P ~12.5K
Asus M4A79T deluxe ~14.5K
Biostar TA790GX A3+ ~6K
These were the options I considered when buying AM3 mobo. Unfortunately G65 was not in stock, considered one of GD70 and A3+. With suggestions from this forum chose GD70 the top performer in most of the reviews.
^^GD FX 70 is the most feature rich among all the listed boards..
if u can spend 10k+ for amd motherboard why not switch to lga 1366 platform. 955 be is priced close to i7 920.
Simialar featured board for i7 920 would be > 16K. Add a bit for triple channel, and 1.5K for proccy. That might mean 8-9K.
If you can afford it, core i7 is a good option and by the way, you might stick to 2 ram sticks, as there doesn’t seem to be muchh diff in performance when using triple channel kit.
