Help with OPNSense, Airtel XStream & bridge mode
I recently switched my second internet connection to Airtel from Spectra because Airtel was offering a good deal in conjunction with my postpaid phone plan, and I thought it would be good to have my public services on two connections (Spectra uses CGNAT). After many weeks of trying to get Airtel support to acknowledge my request to activate bridge mode and a static IP, I finally have it running properly with the Airtel router in bridge mode and my OPNSense router making the PPPoE connection. However, I’m having a weird problem. On ACT, my static IP is automatically assigned by their PPPoE server. Based on my knowledge, that’s the standard mode of operation for PPPoE connections. However, the Airtel technicians insist that I have to configure the static IP they’ve assigned to me on my end and that they cannot bind the static IP to my PPPoE credentials. I’ve tried and failed to configure the static IP in the PPPoE settings on OPNSense. What I am considering now is that perhaps I need to passthrough the VLANs from the Airtel router and configure the internet and voice VLANs on my OPNSense router and then I’ll be able to apply the static IP settings. I’m wondering if anyone has a similar configuration or has faced a similar problem? Would appreciate any help.
If the router is in bridge mode then I believe only the WAN connection is disabled and one of the LAN port is in bridge mode.
The Voice VLAN stays on the airtel router as-is. No changes there.
On OPNsense side you need to get off PPPoE and configure static IP instead. Enter the details such as the static IP, Gateway, subnet mask etc. to make a connection. You can look these up in your airtel router WAN settings I suppose.
Bridge mode is configured for media conversion from fibre (I think it’s an SC connector? Didn’t look too closely) to ethernet on a port as you said.
The Voice VLAN is currently configured on the Airtel router, but I’m planning to move it to a FreePBX VM running on my server eventually as that seems like fun. That’s a project for another day though.
I’m not sure how to ‘get off PPPoE’ though. Some device in the chain between Airtel and my LAN has to make a PPPoE connection, right? If that’s not their ONT-cum-router and not my router, then where does that happen? Or is their network essentially unsecured?
No, PPPoE connection is not required when you have static IP allocated.
@@napstersquest might be able to help since I think he has static IP configured.
To bind a static IP to your PPPoE credentials, you will need to configure your OPNSense router with the static IP as the PPPoE client’s IP address. This can typically be done in the router’s network settings or WAN configuration page. You should also have to configure your router to authenticate with your PPPoE username and password. This information is usually provided by your internet service provider. Once you have done that, you should be able to establish a PPPoE connection using your static IP. Please note that the steps may vary depending on the router model and firmware you are using.
Airtel does not disable your regular pppoe which is why you are still able to connect via pppoe
Airtel assigns you a static IP on a specific VLAN segment (typically 100) and that does not require any pppoe authentication
That part is all you need to configure
In short, Note down your static IP from Airtel CPE (as well as VLAN, subnet mask and gateway IP)
set Airtel CPE to bridge mode to bridge your incoming fiber line to the LAN port of CPE.. which is in turn connected to WAN of your opnsense router
COnfigure Opnsense WAN to static IP with the IP, subnet mask, gateway and VLAN details you noted down in step 1
Thats it
If you have static IP, your router (one connected to bridged LAN port on the Airtel box) has to be configured with the static IP, gateway and DNS provided by ISP.
If you don’t, the same router (yours) will need to be configured with the PPPoE settings.
Thanks for the info! I have all the requisite information so I should be able to configure that in minutes once I get home. That’s great to know.
Out of curiosity, does anyone know how that works on the ISP’s end? I mean in terms of security. What prevents any user from setting a valid IP from the IP ranges Airtel owns in their CPE? Of course they would see that very quickly and be able to stop it, but I had assumed that even with an assigned static IP there would be some sort of security measures on the CPE end to ensure a particular IP can only be bound on the connection it is associated with.
Thanks everyone, took a little configuration (I forgot I had to specifically add upstream gateways in OPNSense) but this worked a charm. I took the opportunity to move the VLANs from Airtel’s router to my own, and the Voice VLAN is also working, which is great.
Rudiv can u guide me throught the steps for setting up wan with static ip configuration. im new to opnsense i cant get internet access i had it running smoothly before with dchp (before getting static ip from airtel )
appreciate ur help
Speak to the head for technical support for your area, he will know how to do this. The person who comes to install is usually reading from script and says they cannot do it.
Just search for WAN settings opnsense static IP on google
Will do that. Though i shouldnt have gone for bridge mode and static ip it was working quite well with dhcp configuration before on my opnsense i just had to jinx it. lets just wait and see if i can get it up and running smoothly.
Opnsense works fine with Airtel static IP.
I was on opnsense + static Airtel for a while.
Although I have shifted back to pppoe (as static IP connections did not get ipv6 after airtel went dual stack some time ago ) but no reason why it shouldn’t work today either
Can you perhaps post a screenshot of your interface setup (opnsense) as well as the WAN settings on the ISP router - someone may be able to spot what’s off
Couldnt get it to work yesterday but its working fine now just had to reboot after filling in wan static ip details .would u mind sharing how did u setup ppoe connection on opnsense im hoping to use jiofiber with it in few weeks and Thank you for your valuable input.
hey guys I also need help with airtel static ip + opnsense + PPPOE
@@rudiv if you could create i guide with screen shot in pdf and post a thread could help future users
Finally got the workaround for the issue atleast in my use case all I had to do was to walk through the wizard select PPPOE and input the credentials and it works!
Hi everyone
Need help regarding Opnsense and Airtel bridge mode.
Currently I am using Deco X20 as main router in bridge mode connected to Airtel ONT. I don’t have LAN ports left as I have also connect my home server to Deco X20 main unit lan port. Another issue I get with Deco X20 in router mode is, if internet is down I cannot access home server on LAN port via WiFi since Deco X20 has auto sensing WAN/LAN ports.
I am thinking to make my home server my own router and use Deco in AP mode. I wanted to confirm few things to ensure I will be able to achieve what I am thinking:-
  1. I have a Airtel ONT which has LAN port 4 in bridge mode
  2. I will connect Home Server via LAN to Airtel ONT LAN port 4
  3. Install opnsense in Proxmox assign 192.168.1.1
  4. Configure WAN in opnsense with PPPoE credentials of Airtel
  5. Once PPPoE is successful connect Deco X20 in AP mode to another LAN port on Home server
Let me know if what I am thinking is correct and I should be able to achieve it. Will use remaining LAN ports on Home server to connect other devices via LAN. @@Leshy @@napstersquest @@superczar @@Leshy
@@inc0d3r I had support from @@Pauljacob who helped me configure the same but if I go the pppoe route in opnsense I was not able to Get static Ip working for some reason
I think if your router has static IP then that IP, gateway, dns has to be configured else PPPoE. I don’t think both will work together. Why do you want to dial PPPoE if you already have static IP assigned. @@napstersquest Can confirm on this
