I basically want to create a header image with web links embedded in it.
So I used the slice tool and made slices and added the links, but when I select ‘Save for web’ the image is cut into slices and saved as individual images (i.e. one image per slice).
So how do I merge all the images into one and yet retain the web links. Or is there any other way to export?
