HOW: Hot-swap MOUSE
Today I got a Laser Mouse. (Review is coming soon)
I want that when I am ‘working’ I want to use my Logitech Basic Optical Mouse (PS2).
But when I want to ‘game’ I want to switch to the Laser Mouse (USB)
Can it be done ? How ?
(I prefer not to plu-unplug cables every time)
plugging in both of them dont work?
How:hot swap mouse…
All you need is a orange box, microwave oven along with two mice and not to forget the comp with a internet connection… Switch on the comp… Install orange box and update portal… play portal and figure out the rest :grinning_face_with_smiling_eyes: evil:
You can’t hot swap a ps2 mouse. If you had 2 USB mice it would have been no problem.
But nuke666 is probably right..plug in both of them, and disable/enable them from device manager.
i had used a ps/2 + usb mouse together for many months without any probs :slight_smile:
i didn’t disable any mouse either
^yup…same here..
Please give details… how was the setup ?
i just connected the usb mouse & removed logitech mouseware :slight_smile:
so you are actually, plug-unplug the cables ?
Nope i dont think you need to.
Should work keeping both plugged in at the same time. Am doing the same thing with my MX-518 and MS optical basic. I use the MX and the rest of the family uses the MS. Keeps their grubby paws off the MX. :slight_smile:
Just plugging-unplugging should do i think. afaik you can use only one at a time
no i used to keep both plugged in :slight_smile:
You can keep them both plugged in !!
Been doing that for almost an year now.
