How much to pay for 3050 6gb if the gpu has warranty and not ?
I’ve picked up these with 12 month official warrantt for around 13k 4 months ago
Not sure about non warranty pieces
13k for used only 2 months msi 3050?
It was used for 2 years and had 1 year warranty remaining
Under warranty - 13 or 13.k
Without warranty - 12k
Good deal go for it
Well the deal called off need to find new deal but 3050 6gb can’t find on sites
I’ve seen lots of out-of-warranty 3060 12GBs selling for ~15k lately. That would be a much better deal if you can extend your budget a little.
That’s actually a blessing in disguise. 3050 is not at all a good card, let alone the 6GB variant.
I bought 3060ti FE for 13.5k and 3070 for 15.5k over the last quarter. I don’t think the prices for low end GPUs have gone that crazy that you buy a 3050 6GB for 12-13k.
I’m having ant eco psu only I cant change new psu that’s why I’m searching for 3050 6gb variant compared to 1650 it’s good right
What’s the wattage? Also ant esports psu should never be bought. They can fry your entire PC anytime.
And if power consumption is a concern, reduce the voltage, core frequency and set a power limit.
A crippled 3060ti will still be far better than rtx 3050 6gb.
Btw what’s your processor?
My pc specs
Ryzen 5 3400g
8gb ddr4 3200 mhz×2
Gigabyte b450m
This is the psu
Psu problem can’t upgrade it that’s why
Fom where you bought
Fb marketplace
