How often to apply thermal goop?
guys how often do you need to apply thermal goop in general? also is it necessary to re-apply thermal paste every time you remove the heatsink?
is it ok to clean the earlier paste with just tissue paper?
The thermal paste’s made to last a while. U need not remove the heatsink to check that and reapply the paste periodically. :joy:
Preferably yes. Since dust and foreign particles might’ve clogged into the paste. Moreover, air-bubbles would get trapped when u place the HS (with the older paste) atop the CPU IHS and lock/fix it.
Well I use a couple of tissue papers dipped with a few drops of acetone. Some peeps prefer isopropyl alcohol (IPA in short) or even the nail polish remover. Basically a solvent to wipe out the earlier goop easily. The IHS has to be cleaned thoroughly before the thermal paste’s to be applied.
lol i didnt remove heatsink to check. but i had removed it while cleaning my cabinet.
i thought using a solvent wouldnt be really necessary, but ill just use nail polish remover.
I use the cotton swabs available in the market. They already come with isopropyl alcohol and it cleans good. :slight_smile:
Don’t use nail polish remover, it has many essense etc compounds, which might damage your processor ! Either use acetone, or concentrated isopropyl alcohol. Else, don’t use anything, but you won’t get a very clean surface with just tissue.
Artic Silver have very good instructions for applying and removing heat sink compounds.
Arctic Silver Incorporated - Route to Product Instructions for Arctic Silver 5
This might help as well. It has all different ways of applying goop based on ur heatsink type.
http://www.techenclave.com/cpu-mobo-corner/thermal-paste-application-method-119409.html
I usually apply thermal paste everytime i clean my cooler completely and that is like once in 6 months. U can even use it for years and without any problem.
It is made to stand extreme conditions so don’t worry. U can apply and forget or use whenever u wish to.
