how to connect set-top box to lcd monitor ?
set top box have composite output…so how can i connect it to lcd monitor which has dvi…
if u mean lcd TV then it has composite input, if u mean lcd pc monitor, then sadly u will need to invest either in a expensive convertor or a tv tuner for the pc which has composite input and then outputs via gfx card to lcd
