How to set the speed for burning cds and dvds on nero 7?
burn using Nero Burning Rom :
File - New - Burn - Set Speed - Select Speed from the drop down list - New
Add your files, then hit Burn.
I don’t think there’s a way to the speed if you’re using Nero Startsmart/Nero Express.
Once you finish adding files .. click on burn icon .. it will pop up the window where you need to set your speed and other properties.
In the final window,click on the little arrow on the left to open a pannel with speed settings.
Thanx for the replies it worked. The last page did contain options of speed. Why did these people hide it?
Thanks everybody.
