HP laptop G6 2005AX scrap parts
Need old components for the laptop model above. I remember that a lot of Indian gamers back then bought this laptop. Guys from digit and erodov had it. If anyone’s laptop died and willing to part with the scrap metal I’d be delighted to get rid of it for you.
Thanks.
bump
I dont have such laptop but what components are you looking for specifically? Because if its hinges are broken, one can rebuild it at home as diy. I have done it for toshiba laptop with araldite.
Multiple internal parts for the HP. Some internal electrical parts like the power connector port (mine was burnt), harddisk connector, cpu/gpu cooler, speaker etc.
Screen (dead pixels) and keyboard for the Toshiba.
bump
Bump
bump
bump
Bump
bump
Here are the parts which I need:
  1. Heatsink fan cooler
  2. Laptop switch connector (6 pin) (this is apparently called flat ribbon cable)
  3. Hardisk connector (7+6)
  4. Speaker connector (4 pin)
  5. Power jack connector (8 pin)
    The connectors are all mini/micro sizes for laptops so standard ones won’t do.
    As for the main power jack connector I don’t know if laptop connectors are universally compatible.
Bump.
I’m having difficulty finding the switch ribbon thing and the heatsink cooler.
bump
did you upgrade the bios??
