I am not able to reply to posts in marketplace section
Select the user to user listing sub category.
same thing happend to me i was able to msg and create posts earlier but for some reason now i cant ??
Dude.. please start reading relevant posts above. Check your trader profile which will show the status of your market access and how far away or close you are from getting the privilege.
@renegade I seem to have lost access to marketplace. I am unable to reply and DM. I used to be able to. Can you please let me know if something is wrong with my account?
This is what is wrong with your account right now. All your posts have been made on only 8 days. You can check the above information in your trader profile.
Same issue here for me, my market access was lost as well. What makes it annoying is the fact that I was able to freely reply on classifieds and even initiate a DM four days ago. Suddenly having it revoked without reason is frustrating.
What does “Active days” even mean? My active days is sitting on 10/15 currently.
Not sure what this additional metric is supposed to achieve considering account age pretty much makes this redundant.
Your replies in technical sections should be spread over 15 days. A lot of members were spamming the required 25 posts on a single day just to gain market access, so this new restriction was placed during the migration.
Posts in deals section were being mistakenly counted towards the requirement for classifieds and DM access. It was identified only recently.
Thank you for the explanation.
So that would mean that the market access requirements is updated such that one needs to post to non-classifieds categories over 15 unique days to meet the requirements? Makes sense why I lost it, if thats the case.
I recently got my market privileges and DM privileges. Today i decided to DM someone and poof I don’t have the privileges.
Why did it happened?
Did i violate any rule or something?
Please check into the issue.
In your profile click on Trader section. There you will see unfulfilled conditions if not having DM privileges.
I remember I fulfilled those conditions a few days ago and i also got the privileges. But now I am just unable to text anyone.
Check the trader section again. If you don’t see those conditions there then the issue is something else.
No, it just says you haven’t fulfilled the conditions like 18/25 posts and 11/15 days active
The it means you earlier got those privileges due to this bug:
hmm, i see it. Thanks for the clarification. Really liked a deal in marketplace seems like I will skipping that or will have to purchase enclave plus
I believe this has done to improve reliability during transactions, But on the other hand just buying the access will give you full access seems contradictory.
Is the counter for trader section removed? Or it is removed for me due to fulfilling the criteria?
It gets removed once you fulfil the criteria.
Either by normal requirements or due to buying Enclave Plus subscription. If normal requirements are not met then once the subscription ends it will be back to no DM privileges.
I have paid for enclave plus on 9th July and from yesterday my messages and marketplace privilege are gone. It even shows that I don’t have enclave plus
