This site is helpfulfor purchasing screws/nuts/bolts etc which will be handy for electronic DIY projects. Recently purchased from them and minimum order quanity is not required for ordering.
Great find, they also have (Mild Steel, Stainless Steel, Aluminium) 1-3mm laser cutting service.
Dang it, I can’t edit the original post anymore, I didn’t know that it cannot be done after some period of time.
I wanted to add the new sites posted by members in the first post, so it can be quickly discovered.
Hey any idea about robocraze and flyrobo they seem to have better prices than robu but never seen anyone ordering from there
They seem to be legit, that said I have not ordered anything from them, but I do see robocraze advertisement on instagram from time to time, so someone there is putting money into marketing, indicating they are serious.
I’ve ordered at least thrice from robocraze and no issues with them so far.
I read somewhere here that you can ask the mods to add info to the main post by reporting your post and putting in your request as the reason.
That was a while ago and lots of things have changed since then but you can give it a try.
It should be easy enough, if it’s not requested often.
+1 for onlyscrews they have a very good support and you find almost all kind of screws and brass inserts.
How’s the price compared to local stores?
Like 10-15% expensive as compared to what you will find in Bhagirath Palace, Delhi. The biggest plus here is that you don’t have to find buy 500 pc packet of specific type. The biggest upside I see is that the dimension mentioned are mentioned on their website, which makes your life a lot easier while designing an enclosure in FreeCAD.
Only screws , super site ,thanks .
Don’t know why people had bad experiences with electronicscomp com
I have ordered some small power supplies and some caps twice. No problem. However from now onwards I will be cautious on orders above 5000
Prices are competitive only. Also, at my place it is really very difficult to source allen socket head type nuts . I wanted to purchase them for my DYI amplifier project and during my search for these type of nuts online, I came across this site.
Avoid purchasing from Electronicscomp; they are scammers.
I made 10-12 purchases over the last 3-4 years. Initially, in 2021, they were good. But starting from 2023, they began scamming everyone. There’s no update after the payment, customer care is a joke, and they either ship partial orders or incorrect quantities. Don’t be deceived by the availability of components and lower prices. Avoid them if you can.
I’ve had great experience ordering stuff from Sharvielectronics.
@@Sanil Thanks a lot. They sell pre cramped jst wires, which is great
you can check omrook as well. cheaper than onlyscrews ![]()
yes, you are right, found to be competive enough and some good rates for single drill bits which is very costly in Amazon, flipkart etc. Thanks for sharing.
Any good source for good stepper motors in India?
I am looking for some good pancake NEMA17 stepper motors but can’t find many options online.
I had good experience with hubtronics, they took about 2 days to ship the order, they claim 12-24 hours to ship, also used a courier I’ve never heard of, Shree Maruti but other than that, it was good.
It is a local gujrat courier. That’s why
