Intel N100 / N150 Mini PCs & ITX Motherboards for NAS, Home Servers & Firewalls (OPNsense/pfSense)
Mini PCs
  • Intel N100 Mini PC [ DDR4 ] - [ 4 x 2.5G LAN ] [ Barebone ] - [ Rs 14399 ]
  • Intel N100 Mini PC [ DDR4 ] - [ 4 x 2.5G LAN ] [ 16G + 256G ] - [ Rs 17999 ]
  • Intel N150 Mini PC [ DDR4 ] - [ 4 x 2.5G LAN ] [ Barebone ] - [ Rs 14999 ]
  • Intel N150 Mini PC [ DDR4 ] - [ 4 x 2.5G LAN ] [ 16G + 256G ] - [ Rs 18599 ]
  • Intel N100 Mini PC [ DDR5 ] - [ 4 x 2.5G LAN ] [ Barebone ] - [ Rs 14699 ]
  • Intel N100 Mini PC [ DDR5 ] - [ 6 x 2.5G LAN ] [ Barebone ] - [ Rs 15299 ]
ITX Motherboards
  • Intel N100 NAS motherboard - [ DDR5 ] - [ 4 x 2.5G LAN ] [ 6 SATA ] - [ Rs 13899 ]
  • Intel N150 NAS motherboard - [ DDR5 ] - [ 4 x 2.5G LAN ] [ 6 SATA ] - [ Rs 14599 ]
Video of all items : https://www.youtube.com/watch?v=iP0NWCATKTk
Shipping : Extra, as far as possible, I will ship through your preferred courier**
Specifications
Intel N100/N150 Mini PC, - 4 LAN, DDR4 version
  • Possessor: Integrated Intel®Alder Lake-N N100/N150 Processors
  • Graphics: Integrated Intel®UHD Graphics
  • Display : 1 x HDMI
  • Memory : 2 x SODIMM, support dual-channel 3200 MHZ DDR4 memory
  • Storage : 1 x SATA 6Gbps, 1 x M.2 Key-M 2280/2242 NVME/SATA SSD
  • Expansion : 1 x Mini-PCIe, support 4G/WIFI module, 1 x SIM (Not included)
  • Ethernet : 4 x intel i225/i226 2.5G network Card
  • COM / Serial port : 2 x DB9 RS232 serial port
  • USB : 2 x USB 3.0, 4 x USB 2.0
  • Functions : Supports - Power on, network wake-up, PXE, watchdog
  • Power supply : DC 12V (Included)
  • Aluminum body
  • Color : Black
Intel N100 Mini PC : 4 LAN - DDR-5 version
  • Possessor: Integrated Intel®Alder Lake-N N100 Processor
  • Display : 1 x HDMI, support 4096x2160@60Hz, 1 x DP, support 7680x4320@60Hz, Type-C interface, support DP 7680x4320@60Hz & USB3.2 Gen2
  • Memory : 1 x SODIMM, DDR5, 4800 MHZ
  • Storage : 1 x SATA 6Gbps, 1 x M.2 M-Key 2280(NVMe PCIe3.0 x2 protocol)
  • Expansion :
    • 1 x MiniPCIe (PCIe+USB2.0+SATA3.0 protocol, WIFI/BT/mSATA/4G module supported),Micro SIM card
    • 5 x RS232/RS485 pin, pitch 2.0mm; 8 x GPIO
    • 1 x 4Pin PWM CPU FAN; 1 x 4Pin PWM SYS FAN
  • Ethernet : 3 x intel i226 2.5G LAN ports, 1 x RTL 8156 LAN port
  • USB : 2 x USB 3.0, 2 x USB 2.0, 1 USB - C, TF card
  • Aluminum body
  • Color : Gray
Intel N100 Mini PC : 6 LAN - DDR-5 version
  • Storage : 1 x SATA 3.0, 1 x M.2 2280 SATA
  • Expansion : E-Key WIFI/BT and B-Key 4G/5G modules / external antenna, TPM2.0
  • Ethernet : 6 x intel i226 2.5G LAN ports
  • USB : 3 x USB 3.0 ports,1 x USB2.0
  • Serial : 1 x RS232 RJ45
  • Power supply : DC 12-19V (Included)
  • Aluminum body
  • 2 x antenna ports
  • Color : Gray
Intel N100/N150 ITX motherboards (Same specs except Processor & color)
  • Display : 1 x HDMI, 1 x DP
  • Storage : 6 x SATA 3.0 6Gbps, 1 x M.2 Key-M 2280, 1 x NVMe/NGFF 2280 (supports NVME & SATA)
  • Expansion : 1 x PCIe x1 slot
  • Backplane IO :
    • 4 x Intel 2.5G ports
    • 2 x USB 2.0 2 x USB 3.0
    • 1 x Audio
    • 1 x HDMI, 1 x DP
  • Onboard IO
    • 1 x 24 PIN, 1 x 4 PIN - ATX PSU input
    • 1 x USB2.0 pin (can be connected to 2 external USB2.0 ports)
    • 1 x COM header 9pin
    • 1 x CPU fan power header
    • 6 x SATA 3.0
    • Front panel header
    • Front panel USB header
  • Size ITX
  • Color : Black (N100), Green (N150)
Why this Mini PCs / Mobos
  • Low power consumption / Suitable for running 24x7 / Proxmox / Opensense
  • 4+ Intel I226v 2.5G ports, Build your own router / Firewall / VLANs
  • Intel LAN ports, Not the Realtek ports ( which are known to be unstable for Routers, firewall)
  • Excellent linux / windows / Opensense supports - works out of the box
  • Excellent performance in its category : Here’s Geekbench i just ran yesterday, the result is better thn 90%+ other N100 builds
N100 CPU Performance
Note
  • All items are new / unused
  • Dead on arrival - Will replace it with new item
  • Shipping : Extra, can ship through your preferred courier if [ if its possible for me ]
  • Intel officially supports 16G memory for N100/N150
Video showcase of all items : https://www.youtube.com/watch?v=iP0NWCATKTk
Hello,
Will the same product be available later i.e. Will you keep a stock of this product ?
I was looking to buy this in a month or 2.
N100/N150 should be available in stock, price will fluctuate lil bit based on exchange rate
Interested in the above but already bought an ITX motherboard recently. Saving this thread for a future order once I have the spare cash and/or if there’s price drop.
Thumps UP for the ingenuity , Pic with username on Youtube
@FortiCore told you people love transparency here
Definitely, and so do I…. I am more of an engineer thn a seller. No **, will have every thing as transparent as possible…..
