Here again with another problem with my Samsung GT-I8000 Omnia 2. I m having Airtel Mobile Office plan for Internet and it is working fine on mobile. But when I connect my phone to PC and connect to internet with Internet Sharing Program available in mobile, internet connect sometimes and sometimes not connected. I mean in mobile, it is showing connected, but when i try to open any site, after 4-5 times reloading the page, the site opens and again the same problem. Idont know wat is the problem. Can anyone with omnia 2 or any other window mobile check with their connection?
Yes, There is a Internet Sharing Program in the mobile by which I connect to net. Is there any other way to connect to internet on pc through mobile? Bcoz from New PC Studio, when i connect to internet, it gives msg that connect using ‘Internet Sharing’ from mobile.
1.Download and install windows mobile center,if you are using xp,google for it,for vista or 7 it is usually present,or obtainable through auto update.
2.connect your phone with the usb cable to the laptop,the phone will give you 3 options,a.mass storage b.active sync c.share internet,check the box c.
3.open windows mobile center,do not do anything,just minimize it,now open your laptop browser.
I had similar problem with htc before,it didnot come with any pc suite,but the above method worked.Not sure about samsung though.
Try these steps
Done as wat u said. But still same problem. Page opens after 4-5 times page reload. Someone with omnia 2 or winmo pls check with their mobile if possible.
Thanks
