iPhone 14/15 Pro Max
Hi
Looking for a IPhone 14/15 Pro max in good condition with battery health > 90%.
Thank you
Do not buy a 14 pro max
You dont want to be stuck in lightning era
Ok
I thought lightening port is also reliable like usb C.
You always have to carry your own cable for most things
Good lightning cables are more expensive than usb c cables
USB C is convenience
That’s totally right.
USB C means universal standard.
just saw mine and it stands at 90 with 500 cycles.. how much could i expect?
Is it 15 or 14
No lightning port is not as reliable as we would like to believe.
Firstly it will mostly work with Apple’s original cable properly ..sometimes it works with third party cables but after few times it shows error.
Secondly it needs careful cleaning too after a while. If you make one mistake while cleaning..toh gaya.
Type C is much better.
Check my DM.
Bump to the Top
