iPhone 15 Pro Max or Samsung Galaxy Fold 5? Which to keep?
For context I have both phones and would like to have an honest debate as to which one to keep.
I’m not much of a photography nut but I do like the iPhone, as for devices I use a windows laptop and plan not to change my ecosystem on a laptop basis but may buy an iPad Mini as I have a lot of reading that I regularly get into a good and healthy discussion may help out. Thanks!
Also keeping one seems the best option for me as keeping two seems like a bit of a chore
iPhone 15, has you can get(thinking of) a iPad Mini no need for a fordable phone.
iPhone 15 because you are getting an iPad so fold is not required also I have had problems with Samsung folding phone’s durability. I had the flip 3 and its hinge started peeling off in less then a year and the service centre guys told that this will not come under warranty. Don’t know about the newer varients but I don’t trust it
Not getting a iPad mini but thinking about that ofcourse if something happens
if you have it on your mind, then just go for it has 2 devices will serve with better usage and battery life. fold will always give you fear of draining out in both the reading and usage. but if you don’t want to have 2 devices then just keep the fold.
I am fully into Apple ecosystem. If you do not have any plans of moving fully into Apple ecosystem, keep the Fold 5. You do not have to carry an iPad and a phone. Using Windows laptop with iOS/iPadOS devices is a headache. With X Elite laptops coming, you will have solid laptops in MS side as well. Moreover, you get to have lot of choice if you want to change to another foldable.
From what you have said, I will go with Apple 15 Pro Max. You have been dealing with 3 ecosystems Apple,Android and Windows, of them you are comfortable with Windows for laptop and iPhone, so you basically said it.
Fold is heavier but flashy and you can attract attention with it. But do note that any service on it will cost a bomb, touchwood.
