Is this Possible.....CAS with DVB PC card and emulator?????
Alrite
I came across this tutorial on some website while searching on google.
It mentions how to use a DVB PC TV Tuner with some card emulator HW and software and use it on the PC
The problem is it is mentioned for TATA Sky.
And there are reports of it not working due to some encryption.
What I want to know is that is there some way to get it working for CAS, so I do not have to use the pathetic STB.
Please someone help me out.
If it is possible can someone have a simpler explanation.
My Card specs :TV Tuner AVerTV Satellite Trinity
  • Input Signal
o 75Ω TV Antenna Input
o S-Video
o Compositie (RCA)
o Audio L/R
o Remote Sensor
  • DVB-S Tuner
o Receiving frequency: 950~2150MHz tuning range
o QPSK and FEC
o Symbol rate/Sec: 1~45MHz
o Viterbi decoding: 1/2, 2/3,3/4,5/6,6/7,7/8
o Input Level: -84~ -20 dBm
o DiSEqC 1.1
HDTV (MPEG-4 AVC/H.264 & MPEG-2) ready
AND Here is the tutorial for reference
) supports MPEG-4 and HD as well.
    * Plugins= SoftCSA / KNCBDACTRL.dll. Multidec plugins = NDScam 0.0.0.4 / DCW.dll. Codecs = Cyberlink POWERDVD mpeg2 / Cyberlink POWERDVD H.264. Put these files into plugin folder of the DVB installation directory. This plugin will read yourTata Sky Card and decrypt the signals.
How it works
As I stated, I have a phoenix smartcard reader which I can put my legal active Tata SKY viewing card into to decrypt both my DVB-S signals via PCI cards. For this to work DVBDream needs a plugin to access MultiDec plugins for which will act as my softcam. softcams are software work arounds to read and use smartcard information without the need for CAM (conditional access module) hardware. The plugin I'm using to access the multiDec plugins is called softCSA, although I know there are others out there. The multiDec plugins I'm using are NDSCAM 0.0.0.7 (update release) and DCW.dll.Tata Sky viewing cards are encrypted using a system called Videoguard from NDS. Combine everything, And it works
i think the access card is locked to the stb h/w number in most satellite tv services.
will it work in the first place?
well first of the avermedia tv tuner u have is for DVB-S,where as ur local cable wala service is DVB-C ,so no u can’t make it to work.
even if u have a TS,or airtel or big tv etc i doub’t u can recieve it since,the dth providers still don’t give u the option for this,the soon to proposed laws by trai will change that.but currently its illegal.
It it possible, but its not easy AFAIK. Also this is probably not the right forum. You should check up in a few satellite TV forums.
well it is possible but if he changes the hardware,he currently has a DVB-T tuner,he needs to get a DVB-C tuner.
but if I go in for Reliance or Tata sky, then I will need a DVB-S card
yes thats correct.
yup and soft emulator usually results in blowing the Smartcard up so if I want this system to work, it has to be DTH and I need one of these two
  1. Pheonix Card Reader + Soft CAM
  2. Cam Reader (like AverTV SatGate) + CAM
second being the more stable option…
looks like i’ll have to stick with what I have, but only till I get an external HD PVR with component input instead of these workaround solutions
