Hi Guys,
Need your help to see how to resolve issue with touchpad for my OMen
https://www.amazon.in/Micro-Edge-Anti-Glare-Geforce-Graphics-16-B0352Tx/dp/B09S9XXTK5/ref=d_pb_allspark_dp_sims_pao_desktop_session_based_sccl_5_5/261-7692196-1107509?pd_rd_w=M7sNR&content-id=amzn1.sym.f9221308-d9c7-4a5c-ac35-a081ae29b064&pf_rd_p=f9221308-d9c7-4a5c-ac35-a081ae29b064&pf_rd_r=K89JT4WVYGRFZQZM4M3H&pd_rd_wg=rbfJJ&pd_rd_r=8f5e2de8-fd49-4d32-b474-af04e4ca5ff8&pd_rd_i=B09S9XXTK5&psc=1
Issue: the touchpad is laggy and sometimes it doesnt repsonds, i tried doing the usual fixes and even reached out to the HP care, they sent a support guy who said there was grounding issue and reset the component.
However, after a while issue came back, has anyone else face this issue ? Currently the HP care said they will replace the touchpad component, but i am worried if it might be an issue with the model itself .
Any suggestions or insights will be highly appreciated.
Disabling and re-enabling the touchpad using the keyboard shortcut will temporarily fix the issue. This issue seems to happen to specific Omen & Victus models.
As you said, this is definitely grounding-related. Refer to this [Reddit post](’
https://www.reddit.com/r/HPOmen/comments/wp7tkh/hp_omen_16_touchpad_issue_guaranteed_fix/’
) for the permanent fix. I do not think that replacing the touchpad will help.
I too noticed this on a Victus that I got for my sister. However, before fixing the grounding, I applied a full-body honeycomb wrap on it (including the touchpad area). After this, the issue seemed to go away and so I left the laptop as it is.
Thank you so much for the response. Since the laptop is just 3 months old. i feel a little hesitant in using the wire hack. i might use the wrap . i anyway use it in the back . will use complete , seems to be a static issue for sure. Thanks again
