Karbonn Launches A27 Retina With 4.3" qHD Display, Dual-Core CPU Running Android 4.1 Jelly Bean
Karbonn has quietly announced another mid-range Android smartphone called Retina A27 which features a 4.3inch qHD screen and dual core processor.
The Karbonn A27 runs Android 4.1 Jelly Bean OS and is powered by 1.2GHz Qualcomm Snapdragon processor. It has 4.3 inch qHD IPS display with 960x540 resolution and 8MP rear camera with LED flash and front facing 2MP camera.
Full Specs Include-
  • Dual SIM support
  • 4.3-inch qHD IPS display with 960x540 resolution
  • 1.2 GHz dual-core Qualcomm Snapdragon processor
  • Android 4.1 (Jelly Bean)
  • 9.1 mm thick and weighs 126.5 grams
  • 8MP auto focus camera with LED flash, 2MP front-facing camera
  • 512MB RAM, 4GB of internal memory (2.79 GB user memory), microSD slot supporting up to 32GB
  • 3G (HSDPA 7.2Mbps) , WiFi 802.11 b/g/n, Bluetooth, GPS / aGPS
  • 3.5 mm audio jack
  • 1800 mAh battery
The specs look quite decent and the design and built quality also seems to be good. It is priced at Rs 11,990 but available at Saholic for Rs 9090.
