LED or LCD
It shows that LED gives better pics bla bla bla but has anybody seen any remarkable difference between normal LED and LCD ?
As fr example take these two - LG W1953T LCD Monitor - 19" Widescreen LCD Monitor (18.5" diagonal) - LG Electronics IN
And
LG E1940S LED Monitor - 18.5" Slim LED LCD Monitor E40 (18.5" Diagonal) - LG Electronics IN
Any significant difference while playing game or watching movie ?
Yes some difference is experienced between LED and LCD monitors but these LED monitors are just LCD’s with LED backlit
just a difference of 300 bucks as in the link given by you so better go for a LED one
Ya, you will also save on power a little!
LED backlit gives u more vibrant and brightness then older generation cfl backlit screens.
LED displays take less power and attain lot better black levels. Go for LED backlit display.
yes and they don’t cause eye strain even after sitting front of them for hours and hours
Just check the Power Consumption of LED monitors and LCD monitors. LED monitors consume aprox 40-45% less wattage than LCD. In cheaper versions of both LED and LCD, same panel technology is used. LED LCD monitors has LED backlight whereas normal LCD has fluorescent backlight. for more detail just google.
Guys while googling yesterday i stumbled upon a acer led monitor s231hl
its a 23" led monitor costing just 10.8k with power consumption of just 17w
but cant get any reviews on it as its a newly launched monitor
guys i’m really confused wether to buy g22hd(1,920x1,080) benq lcd or the E2040T(1600 x 900) lg led??
How is LG’s after sales service?
I have an opposite experince, switch to LED from LCD caused much strain, and my laptop with LED is now always on least brightness level, actually LED is tooooo bright, u cant handle lot of brightness for a long time.
