LG monitor deal
@@Desktop @@rocking @@Iamthat108
which monitor did u guys ordered finally out of three and if received please give short review with pros and cons u felt…
@@Aman1829 Have ordered this LG UN880 4K IPS 60hz monitor. @ 21999 + 59 ₹
https://www.flipkart.com/lg-ultrafine-80-01-cm-31-5-inch-4k-ultra-hd-ips-panel-hdr10-ergonomic-usb-type-c-monitor-32un880/p/itm1a0c4652a8d63?pid=MONGTJFYT9ZNXYFB&marketplace=FLIPKART
Its still in transit, delayed at main hub, thats unusual, will update if and when i get it delivered undamaged, in working condition.
btw this monitor is still in stock at same price…(talking about 32inch 4k one)
Yes, its still available at discounted rate. Whereas both 24 and 27 inch QHD 75hz monitors went OOS withing few hours, but this 32inch one is still in stock after 48 hrs. Don’t know why, I have ordered it mainly for media consumption at 4k, hope 60hz is not an drawback. Lets see.
I ordered this monitor (LG UltraFine 80.01 cm (31.5 inch) 4K) and currently waiting to receive let’s see if this is real or some kind of scam, I will surely give Review with pros and cons
Same with me, I also ordered this monitor and mine will be delivered on 26 may so let’s see I wanted a 4k monitor for media consumption and 4k video editing so i think this was good choice for at this price if i received the product undamaged and good in condition then will surely give review
they will deliver for sure… and most probably in right condition too..
this is a superb monitor…my cousin has this same 32 inch one which i ordered for him more than a year before…perfect for the mentioned need.. and yes its speakers are just awesome have watched cricket match without any issue in 4k and using its speaker… best speaker in a monitor till now
@@Desktop
what was the price back then? the reason why i am suspicious cause there is not many monitor at this price that offer 4k IPS and 32 inch and the strange part is that same model for 27 Inch is costing more than 32inch so idk if this works then it would a great deal FS
its normal price that time was Rs 47k to 50k approx, I am talking about nov or dec 2023 approx… yes 27inch is costlier now than 32 inch now because 32 inch is at too lower price right now due to clearnce sale type of thing or you can say too good of a deal…btw 27 inch that time was around 34k to 36k…
does 32 inch doesn’t feel too big while working or doing some tasks?.
it may feel big, but you need to adjust the scaling and also you need to sit at some fix distance and it will be good if you have big desk space too, than it wont feel big and will be perfect .
I have same doubts. My speculative guesses are - this model was launched in 2020, limited to 60hz, while VA panel 144hz ones are available around 35k ₹, they might be planning to upgrade of same monitor aka new model, hence might be dumping stock in India.
I was using 24inch 144hz + 24inch 60hz monitor for gaming + media + productivity - i.e. excel, charts and all.
Got 31.5 inch 1440p mainly for productivity and larger display last year - was apprehensive as it has approx 95 PPi, and distance between sitting position was approx 40 inches. 95ppi is same as 24inch 1080p one. So no issues there. Initially it felt too large, but eyes adjusted in 8-10 days. Closest i sit is 36 inches - no problem. Now i prefer 31.5" 1440p over 24" for productivity (dual monitor setup, makes multi-tasking easy).
Now coming to 31.5" 4k 60hz. My only concern is its low refresh rate - for fast action scenes. For productivity i.e. documents, charts, excel sheets - one can increase font size (scaling) / Change Resolution settings to 1440p in “Display Settings”
@@drtgns - if you can sit 36+ inches from 32" monitor - will take few days to adjust, no other issues.
Good to know, if it din’t lag in cricket match, then most probably 60hz would be fine atleast for media. Won’t use monitor speakers as i have dedicated speakers and stuff for sound, but still good to have in case one needs it.
