anyone purchased this monitor during the deal? seems like it has display issue, the brightness seems to randomly go dim at random time.
Flipkart lost it in shipping, never received it, so can’t tell.
[HEADING=3]@Iamthat108 received it, he might shade more light about it. [/HEADING]
how can they lost a huge box.
I do not have such issue. Working fine, got it for 34k from FK.
Check for a setting in the monitor menu? Or maybe in the OS you are using somewhere? (Automatic Brightness etc?) Or something to do with power/idle settings like “Automatically Dim Display after X minutes”?
it was fine before in my old 27 4k monitor, it happens during active uses
Check the settings as mentioned by @@vishalrao, and turn OFF smart energy saving (it’s in the general section in my OSD for LG 24inch monitor).
turned off energy saving which was set to low.
did it make any difference?
i can’t confirm it yet because the dim display was happening for few seconds one or two time. will let you know soon.
sometimes this dimming happens when there is no moving images/video on the display… try leaving your monitor idle (dont move mouse or play videos etc) static image… then the idle/dimming kicks in after like 5 minutes or something and it will go back to normal when there is some visual movement on screen.
