@@PunkX 75 @@Tracer_Bullet
How do you think the Montech Air 1000 compares to the Lancool 216?
Apologies for the ping.
you can make a acrylic sheet side panel for you chosen case and keep the tempered glass bubble wrapped some where safe.
No idea. I don’t follow cases, only looked at them when i needed to buy.
I asked a well informed forum user for his opinion, he gave me 3 options and i picked one. 216 was very well reviewed. So that was it.
Kitguru had a good revew/usage guide for 216.
This is for Monteck. You can try to search reddit for opinion + check who they compare against one another, older case wont have comparison against newer one.
Also look at lian li 207 which seems to be a more compact version or 216 and has good cooling.
Not sure if it’s the same case but -
Will it fit dual GTX 1080ti alongwith Corsair HX1200 PSU? Any way to check that?
Check your card dimensions on manufacturer page hx 1200 is a 180 mm psu as per specifications, max supported gpu size is 338mm
Won’t be able to add bottom intake fans for sure. Just buy an ATX cabinet.
Phanteks enthoo pro 2 / 719 , limited stock now but this was available on Flipkart sale.
Perfect case for ml in budget imho
I have this but I don’t think I’m fully utilizing the potential vs the space it occupies.
Don’t see cheaper hdd anymore to fill in the hdd space or can’t budget for itx build as itx tax is expensive
So I’m really holding on to this to wait for intel arc pro lineup.
10/10 case
