Looking for suggestions for a decent budget water purifier
Hi
Was looking for a water purifier to be used in Delhi with Delhi jal board water,
As the supply comes twice for 2.5 hour so that’s when a water pump is used to draw water and filter it via purifier…
The water quality from source is pretty decent most of the time as we haven’t been able to find any smells, cloudiness, sand etc in water..
RO system aren’t required.. Specifically looking for a model with decent uv uf systems which has low replacement filter costs..
Please suggest decent water purifiers which have low filter cost and low service costs.
Till how a uv, carbon, uf purifier from aquaguard was being used, I am a bit biased towards eureka Forbes, aquaguard as they have generally served well
Thanks
There is a huge thread. Do a search..
So you think I haven’t done that..
Asking for a model not looking for gyan
