Some time soon, I expect to stop having a PC at home since there will be two laptops that cover everyone’s needs. I want to replace the PC with a low-power NAS box for data backup. I am looking to build a box with the following features:
Cheap (less than 10k) (edit: forgot to say that)
As small as possible.
Low power
Able to host two SATA HDDs (four is ideal)
Network adapter (wireless not essential)
USB ports to attach removable drives for data transfer
Support Linux (I intend to run a combination of LVM, software RAID, SAMBA and NFS)
No graphics required (edit: forgot to say that too!)
I am newbie to acquiring hardware of this kind … what I found from my preliminary search is that the Zotac Ion seems to be what I need. Are there other options?
The Sheeva Plug is indeed nice, but I want to build something which can also host the HDDs … no point in having one really small box with two USB cases sitting next to it, and each one having its own power supply!
World Edition II has all the right features … but that’s freaking expensive! I plan to build my own box, and would like it to be as low as possible inside of 10k! Also having it run Linux will give immense flexibility, allowing me to run my own scripts off it instead of just being a dumb box.
I guess what I am looking for is an ultra-small PC, that I will use primarily for storage … here is one from Via, but I don’t know if it is available in India, and at what price:
Get Atom single core & a GigE NIC + 1 or 2 Green HDD. Run ubuntu server with webmin and software RAID. Hook that to a GigE router, you will get faster NAS box than you can get for this price range. What more, you can run torrents as well on that box. If you want more computing power get the dual core atom minus the NIC.
Promise SmartStor 4300N is what I guess you are looking for. Priced at $370 and around Rs.25K in India (Genesis - Broadcast, Streaming and Storage) it is a bit expensive. I would say go for an Intel Atom based machine.
Get an Intel D945GCLF Atom 1.6 GHz mini-ITX board + CPU for ~Rs.3.1k. Add a DDR2 667 DIMM, two 500 GB SATA HDDs and a PSU/Cabinet, and you’re good to go for below Rs.10k. Wall-plug power consumption is about 40-45W, of which the two SATA drives alone will account for about 25-30W.
As an added bonus, the Atom supports EM64T (X86_64) as well as Hyperthreading - it’s about 3x the performance of a P3/800 at 1/5th the CPU power dissipation.
