Lowest capacity and cheapest NVME drive and DDR4 laptop DIMM - location Madurai
Looking for a 128GB or even a rare 64GB NVME and 4GB or 2GB DDR4 laptop RAM since it is only for stand by and testing purpose.
Location to ship Madurai - India post registered post would cost less than Rs.25 from Delhi
No longer exists.
Holy cow. :frowning:
I just sent one last week. So I am among the last few members to use it :slight_smile:
So, you are the reason it was stopped. Thanks for ruining it for all of us @Karthik_G .
I have few ram sticks, but I don’t know where they are right now.
Will find it and let you know.
BTW I’m from Trichy.
I have 4gb ddr4 sodimm. Can give it u if I am able to get 16gb ones.
Ddr4 requirement is fulfilled.
Looking for 128gb or smaller nvme
@TheD4ddy may have some
I have a 64GB M.2 SATA if you’re interested.
Thanks. Let me check if the slot would support it first
Still looking for a 128GB or 64GB nvme or nvme slot supported drive
I have 128gb m.2 sata drive. It works on any m.2 2280 slot so it should work on yours too.
it might work but all NVME slots do not work with M.2 sata slots
Do no one have old and small nvme for cheap?:slight_smile:
