It allows you to connect your speakers to your computer.
24k gold plated connector resist corrosion and ensure a perfect connection with a simple twist of the connector.
#Fully Shielded - Pure Crystal Oxygen Free Copper Cable
Easy to install
It is Durable
It is robust.
It is reliable.
Compact in size.
1.5 Meters
To order post in here. Limited stocks. Kindly dont compare it to the other cables there in the market its way ahead and way superior to those. The connector look the same as in the picture put up
^ as of now only these are. You guys can mention what high quality cables your looking in for and i will get back to you with prices and stocks of the same. if we have a decent number only then will i be able to get it.
guys what other cables are you looking for and length. am gettin some cables from china and sg in the next month . your needs will help me decide what to get in. remember am referring here only to good quality cables that are not easily there in every store
