Hi guys,
Need some advice regarding CPU and motherboard upgrade. The motherboard should have on board graphics ability because I’m not buying a graphic card right now. Further, I may upgrade in the future in terms of RAM/CPU/HDD if required.
I was initially going to go with Intel G2020 and Asus P8H61-M LX3 as is suggested on a few other threads but then I realized that the Asus P8H61-M LX3 only supports RAMs upto 1333 MHz whereas my RipJaw RAM is 1600 MHz so I thought I might as well ask before purchasing.
All help is appreciated.
Thanks a lot !
Questions
- What is your budget?
- 8-10k (Really prefer not to exceed this budget)
[*]What is your existing hardware configuration (component name - component brand and model)
PSU - CoolerMaster eXtreme 500W
Cabinet - CoolerMaster Elite 311
RAM - G.Skill RipJaws 4GB DDR3 1600 MHz
Monitor - BenQ G922HD 18.5" LCD TFT 16:9
Hard Disk - Western Digital Caviar Blue 160 GB
[*]Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
CPU - Intel G2020
Motherboard - GA-B75M-D3H
[*]Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
- I may buy a graphic card and a better RAM/CPU in the future for the purpose of gaming, but only if required.
[*]Where will you buy this hardware? (Online/City/TE Dealer)
- Online or Lamington Road
[*]Would you consider buying a second hand hardware from the TE market
- No
[*]What is your intended use for this PC/hardware
Gaming (Mostly)
Downloading
[*]Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
- No
[*]If you will be playing games then which type of games will you be playing?
BF4
Counter Strike 1.6
Team Fortress 2
[*]What is your preferred monitor resolution for gaming and normal usage
- Highest resolution possible on my monitor 1366x768
[*]Are you looking to overclock?
- No
[*]Which operating system do you intend to use with this configuration?
- Windows 7 64 bit
