My PC is ready for assembling, but I’m still confused about the best motherboard. :huh:
I needed your help regarding:
BEST MOTHERBOARD FOR INTEL Q6600 QUAD PROCESSOR .
Motherboard should have PCI Express 2.0 x16 since I’ll be using Nvidia 9800 GTX+ SC Card.
Help Needed Urgently. :huh:
gforce
April 22, 2009, 6:27am
2
BEST motherboard? ASUS Rampage Formula.
For something a little less heavy on the pocket, check out the Gigabyte GA-EP45-UD3P.
Sorry about not telling my budget:
My MOTHERBOARD BUDGET-> Rs. 6,000/-
Any Intel Motherboard with PCI Express 2.0 x16 and support of Q6600?
GA-EP43-DS3L@5.5K(has solid state capacitors and energy efficient)
This has PCI-E 2.0 x16…
i think even the G31S2L board@2.4K has a PCI-E 2.0 x16(someone plz confirm this)…
gforce
April 22, 2009, 6:38am
5
Gigabyte GA-EP43-DS3L - 5.5K or ASUS P5QL Pro - 6.5K
madnav
April 22, 2009, 6:45am
6
dont convert $ = 50xRs…
kmd rate is $x70Rs
as for the topic…
u donot require pci-e 2.0 x16…the card will work just fine over pci-e x16
look for p45 boards from msi in that price range…or try getting use p45 asus/gigabyte from market section.
save cash n settle for a cheaper board incase u wont be using all features.
Gigabyte GA-EP43-DS3L - 5.5K or GA-EP45-UD3P - 5.5K
Which one is better?
and will it go with Cooler Master 500W SMPS?PSU?
I’m Getting Cooler Master 500W SMPS/PSU at 2k.
gforce
April 22, 2009, 6:53am
8
Richi_Ric:
EP45-UD3P for 5.5k in the local market is almost impossible unless you order it from the U.S. (not via KMD but through other sources).
Under 6K, the EP43 or P5QL Pro are your best options.
Actually what is this KMD???
Yup i edited my post… Think i was editing while u wer replying…
So at last Which is Best Gigabyte Motherboard Under/in Rs. 6000. [Rs. 6k]
Amien
April 22, 2009, 7:10am
11
Richi_Ric:
Get G31M ES2L and buy a better power supply + better GPU. Don’t bother with PCI-E 2.0.
Richi_Ric:
Plz Reply I’m Waiting
What about the few suggestions given by the members… Didnt notice them???
Yep Noticed all But In END I’ll Need one answer.
Whats the price of GA-EP45-UD3P ?
user65
April 22, 2009, 8:16am
15
Get any of these P45 mobos from MSI:
MSI P45Neo-F :5.8k
MSI P45Neo3-FR(PCB1.1) :4.75k
MSI P45CNeo-FIR :6.6k
are they better than gigabyte?
I want best motherboard in Rs.6k
How about Gigabyte GA-EG43M-S2H?
I dont Know its cost.
gforce
April 22, 2009, 8:21am
17
P43>G43 mobos if you’re gonna use a discrete graphics card, which you are.
@gforce
Thanks for the info
user65
April 22, 2009, 8:28am
19
P45 is better than P43 and G43. Those MSI mobos r the best P45 based platform u can get for Intel around 6k.
Amien
April 22, 2009, 8:34am
20
Im sorry, i have no clue as to what you’re on about
