Q: What is your budget?
A : 70-80K (max. 90K)
Q : Which hardware will you be keeping (component name - component brand and model)
A : Intel core 2 duo 2.93 GHz & 4 GB ram , speaker, mouse & keyboard
A : CPU: i7 3770 , Ram : 16 GB , motherboard : don’t know which is good for my work (i guess i’ll go with some good Intel mother board for now), cabinate : Corsair 400R , PSU : 1,00W or a bit more & CPU COL : Cooler Master Hyper 212 EVO & Graphics Card : good for rendering & Animation (NVIDIA)
ps : if i’m missing some parts , please correct me
Q : Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
A : Yes , will upgrade within 4 to 6 months
Q : Where will you buy this hardware? (Online/City/TE Dealer)
A : orissa (from local dealer)
Q : Would you consider buying a second hand hardware from the TE market ?
A : No
Q: What is your intended use for this PC/hardware ?
A : 3D Animation , Motion Graphics & rendering
Downloading , watching HD movies & browsing internet!
A : I don’t like AMD . .I’m a Intel guy
Q : If you will be playing games then which type of games will you be playing?
A: I don’t play much games , I need this Pc for my work
Q : What is your preferred monitor resolution for gaming and normal usage ?
A: 1920×1080
A : No
Q : Which operating system do you intend to use with this configuration?
A: Windows 7 64 bit
