I just got into photography and got a Nikon D7000 handed down to me, but the rear display is so dim that it’s basically unusable for checking sharpness or exposure on the spot. I’ve already maxed out the Monitor Brightness in the Setup menu, but it’s still far too dark to evaluate focus reliably. Because of this, most of my shots are ending up out of focus since I can’t judge sharpness from the LCD after taking a picture.
i mainly run 18-200mm f/3.5-5.6G ED VR II AF-S DX on my camera , but the AF is not accurate at night and if the scene is too dark im not able to use the optical viewfinder to judge the sharpness of the image .
Is there anything i can do to improve the screen quality? Any suggestions would help
During day time, you could use the viewfinder. If that doesn’t cut it then an external screen seems to be the only realistic option, it might get pretty expensive though.
I think I’ve seen some shades/hoods for the lcd for some cameras too, might be helpful.
The LCD should be serviceable at night though right?
On a 3 inch screen that’s still pretty sharp and definitely enough to pull focus properly. If you’re having trouble you can always use focus magnification or whatever it’s called on Nikon cameras. I think there’s something called live view where you can zoom into the live image to check focus, not too sure since I haven’t used a Nikon in a long time. That helps a lot on smaller screens to manage focus.
I don’t think it is a problem of focus. It is a problem of long exposure time and your inability to hold the camera steady. It is difficult to take handheld pictures in the dark with such small apertures. Try putting your camera on a tripod or a table and then take the picture. Moreover, autofocus should not be a problem even in night. Try changing your autofocus setting to center only instead of automatic. Then, focus on the object in the center, then lock the focus by half pressing the shutter button and then compose your image properly and then full press the shutter to click the image. Autofocus is much more reliable when it knows exactly where to look.
If the camera is in good condition (apart from the display) then it might be worthwhile to get the LCD replaced, that is if you decide to keep for the long run. Spare parts ought be easily available as this was a popular model back in the day
It is a 15+ year old model now, not sure how old your particular body is. Wouldnt make sense to sink in much more money to fix it. a few K here and there might be fine but it might be better to cut your losses and sell. External display etc. are an expensive bandaid solution.
