Need advice on buying Monitor for Laptop
Hello All,
I’m planning to set up a dual-monitor setup, but for now I’ll be buying just one monitor (might add another in a few months or later). I’ve checked out a lot of options online, but I’m a bit confused. Need your suggestions based on the requirements below.
Monitor Requirements
  • Main use: coding, browsing, Teams/Zoom meetings
  • Secondary: light web design, graphics, video editing
  • Laptop ports: HDMI and USB-C
  • Screen: 24" or 27", IPS / LED / OLED, thin bezel if possible
  • Budget: under ₹10K, can stretch to ₹12K–15K for a better option
  • Desk: small, so prefer compact setup (I have an external stand already)
better to order online or check Lamington Road? Any good/reliable store suggestions?
Can any one please suggest?
Check this thread
If you want QHD along with Type C, Type A & HDMI ports
If you want FHD with just HDMI and DP ports
I am continuing this thread to avoid duplication. I could not buy a monitor earlier due to some circumstances.
I am now looking to buy a 27-inch QHD (2560×1440) monitor with a budget of around ₹20,000 (can stretch slightly if it makes a meaningful difference). Please suggest the best options available in India.
Use case (priority order):
  1. Coding, reading, spreadsheets (long hours)
  2. Office calls and media consumption
  3. Light to moderate gaming (optional)
Preferences:
  • IPS preferred for text clarity and viewing angles
  • 75–100Hz is sufficient; higher refresh is a bonus if it does not compromise panel quality
Thanks in advance.
Do you need monitor with type c port?
HDMI is fine. but open for all suggestion.
