After much consideration on all the suggestions that have been made on this thread, I am more closer to come to a conclusive decision.
I have some queries for which I will appreciate your feedback, and I also request you guys to please list down a proper future proof mid-high end current gen AMD CPU config and a current gen INTEL CPU config. The components i want to settle for should not be a compromise be it even Case fans or Thermal paste.
Queries**:**
If my usage is going to be mainly 3 things and that is Gaming on a high refresh rate monitor, using Nvidia shadowplay for some gameplay recording and video editing on filmora, then will the AMD 7800X3D suffice?
What series of AMD motherboards are of the same league as Intel’s Z790 series?
What should be the BIOS settings and Windows 11 OS settings that I must change whether I go with AMD CPU / INTEL CPU or Is there any specific thread on TE or elsewhere that guides the user step by step to the things to do once an AMD/INTEL system has been built?
What is the best CPU air cooler out there which is not too noisy for the AMD AM5 platform?
Do you guys suggest I go for an air cooler for the 7800X3D? Or AIO. I wont be overclocking.
And what do you all have to say about this review of the 7800X3D. PCMAG have not praised it like how some other reviewers have done. After reading the review I am now confused :neutral:
[HEADING=2]“THE BOTTOM LINE[/HEADING]
With ho-hum CPU performance for the money, AMD’s gaming-minded Ryzen 7 7800X3D is a tough sell as a mainstream CPU, given that its strengths will benefit only a small sliver of gamers.
[HEADING=2]PROS[/HEADING]
Large amount of cache
Energy efficient
PCI Express 5.0 support
[HEADING=2]CONS[/HEADING]
Sluggish (relative) performance for the money in CPU-intensive tasks
Runs hot
Pricey for the performance level**”**
https://www.pcmag.com/reviews/amd-ryzen-7-7800x3d
Important notes:
I am someone who wants to spend less time trouble shooting hardware or software problems when I am at my desk. I don’t even remember the name of the AMD cpu I once owned some 15 years back. That doesn’t make me an Intel fan boy, it’s just that personally for me Intel and Nvidia combination has always been a hassle free experience and a love affair I am quite happy with and that’s the reason I am hesitant to switch to AMD.
I prefer the high end variants of Intel and Nvidia CPUs/GPUs and my upgrade pattern is usually after every 4-5 years.
For me the 1% lows also matter as much as higher frames. And I don’t want any stuttering.
So keeping the above in mind, please fill in the blanks with your suggestions for high end components and their brands that you guys would just buy and want to forget upgrading for the next 5 years.
| INTEL CONFIG | AMD CONFIG |
| CPU: ? | CPU: ? |
| DDR 5 RAM : ? | DDR 5 RAM: ? |
| M2 Gen 4 SSD: ? | M2 Gen 4 SSD: ? |
| Motherboard: ? | Motherboard: ? |
| Case Fans: ? | Case Fans: ? |
| CPU air cooler: ? CPU AIO: ? |
| Thermal paste: ? | Thermal Paste: ? |
