Need help building my workstation PC
I am planning to build a new PC. It is mainly used for code compilation(mainly rust which needs powerful CPU). Budget range is 90-110k.
Didn’t include a gpu as of now as I don’t have budget + time to game. But will add one in future when I have funds, maybe 9070xt. Hence added 850W PSU.
I don’t need high end parts, but added famous ones, like noctua air cooler. Will be open to others if get almost equivalent experience at lower price.
Also I don’t need 64GB now, so will be buying single 32GB stick and in future will buy another of the same. Any suggestions? Also no need of SSD.
PCPriceTracker Build
Category Selection Source Price
Processor AMD Ryzen 9 9900X Processor with Radeon Graphics (12 Cores 24 Threads with Max Boost Clock of up to 5.6GHz, Base Clock of 4.4GHz, AM5 Socket and 76MB Cache Memory) Variety Online 39949
Motherboard Gigabyte B850M GAMING X WIFI6E AM5 M-ATX AMD Motherboard Variety Online 15389
Graphic Card
Power Supply Corsair RM850X 850 Watts Fully Modular Power Supply (CP-9020270-IN) Computech Store 10599
Cabinet Corsair 4000D Airflow Cabinet (Black) (CC-9011200-WW) TPSTech 7499
Memory Corsair Vengeance RGB 64GB (32GBX2) DDR5 6000MHz CL40 Memory Kit Black Computech Store 18669
Additional Memory
Hard drive
SSD drive
Additional SSD
Monitor
Additional Monitor
CPU Cooler Noctua NH-D15 140mm CPU Air Cooler Vedant Computers 8950
Keyboard
Mouse
Headset
Case Fans
Grand Total INR 101055
if pc is not for gaming, then why select gaming mb?
also if workstation pc then extra pcie slots would come in handy in future so ATX board makes sense in this case.
Adjusted to this config. Any suggestions? Am I spending too much on motherboard? Also buying total 64GB now as combo is cheaper.
Motherboard MSI Pro X870-P Wi-Fi Motherboard Computech Store 21294
Graphic Card
Memory G.Skill F5-6000J3636F32GX2-RS5K Desktop Ram Ripjaws S5 Series 64GB (32GBx2) DDR5 6000MHz (Matte Black) Computech Store 16749
Additional Memory
Hard drive
SSD drive
Additional SSD
Monitor
Additional Monitor
CPU Cooler Deepcool AK620 120mm Dual Fan CPU Air Cooler (R-AK620-BKNNMT-G) TlgGaming 5499
Keyboard
Mouse
Headset
Case Fans
Grand Total INR 101589
yeah changed motherboard
You can do work on a system with a motherboard with “gaming” in the name.
Just saying.
You went from a motherboard that costs 15k to one that costs 21k to avoid the gaming branding ?
If it’s for going ATX , then fine. If not…
I went with this one because of better vrm power delivery, better vrm cooling, pcie 5 future proofing, two type c port.
Mobo change to Gigabyte X870 Gaming X WIFI7 Motherboard available for ₹20,999.00 now.
RAM change to Patriot Memory Viper Venom RGB DDR5 RAM 64GB (2X32GB) 6000MT/s CL30 UDIMM Desktop Gaming Memory Kit PVVR564G600C30K. Worth the 1k extra, available for ₹17,799.00 now.
For Cabinet check here for 5000D.
Is 110K your max budget for entire system unit?! Because all these components will not fit in under that budget.
110k is without gpu. Also is patriot good and reputable brand?
You need only the products you’ve selected and don’t need Storage, KB, Mouse, Monitor etc.?!
Yes. Only those products. Have everything else from my old PC.
In that case get Super Flower Leadex VII 850W Platinum Pro ATX 3.1 Fully Modular SMPS. Worth far more than 1k extra at ₹11,590.00
It is in terms of pricing, for RMA you would have to ship to taiwan if your dealer doesn’t agree for a replacement.
Same for Gskill.
What about super flower. Does it have good customer support in India?
Hi , I dunno if you are okay with buying used components, there is one high end pc for sale in this forum, Threadripper desktop PC (Zen 2 based 32 core 3970X with 128 GB RAM) for sale in Pune! - #35 by vishalrao
I think it will meet your requirements
Never considered Intel (265k) as internet made it seem that intel was not upto par with AMD for last few years and struggling . But seeing reviews of 265k and its price of just 31,999 while delivering similar performance(in some cases better) is enticing. 8000Rs cheaper.
Now got confused more. Probably leaning towards intel
Even I’m trying to know but didn’t find any concrete info on internet.
You’re right if you consider only CPU pricing, but once a quality Z890 board is included the cost gap narrows. The Ryzen 9 9900X is a Zen 5 AM5 CPU built on TSMC 4 nm with a separate I/O die, while Intel’s Core Ultra 7 265K (Arrow Lake) uses a 3 nm compute tile plus other tiles on N5/N6 and runs on the LGA-1851 socket with Z890/800 series boards.
The 265K has 20 cores (8 performance + 12 efficiency), giving it stronger multicore throughput than the 12-core 9900X. Single-thread results are close and workload-dependent. Its Xe-based iGPU also provides higher FP32 compute and AI TOPS compared to the 9900X’s integrated Radeon iGPU, which is more limited. But dya-to-day performance difference is yet to be seen. I read somewahre that in compression (7-Zip) 265k is slightly behind the 9900X under identical memory conditions.
On the security front, Intel processors (including Arrow Lake) remain subject to transient-execution vulnerabilities (e.g. Spectre / Meltdown families) that require microcode and OS mitigations. Recently, Intel also disclosed 10 high-severity GPU/driver vulnerabilities affecting integrated graphics software and drivers. Microcode patches to mitigate new CPU vulnerabilities have also been released for Arrow Lake. The mitigation overhead tends to be low (a few percent) but depends on workload and patch status.
If platform support matters then AMD’s AM5 is guaranteed through 2027 (as advertised and track records), allowing future Ryzen upgrades without a board swap. Intel’s LGA-1851 is new and supports Arrow Lake now, but its long-term roadmap beyond the first generation is not yet confirmed.
If your priority is best multicore performance and a stronger iGPU today, 265K often wins in benchmarks. If you prioritize upgrade stability, avoiding driver/firmware risk, or conservative security exposure, the 9900X + AM5 path is safer.
